"DYNO" Numbers For SOFTAILS
Old Apr 27, 2010 | 12:14 AM
  #291
oct1949's Avatar
oct1949
Originally Posted by HDcustom76
2009 Softail Custom
The Intial Stock Dyno had me at 60.7 HP....
I added :
V&H Big Radius
HD Screamin Eagle A/C
TTS Master Tune
HP: 78.7
T: 92.6
Thanx to the boys at ROSA'S CYCLE in Huntington,NY..Im very happy with the results!
Could U at least post the sheet.. I'd like to see this one...
Old Apr 28, 2010 | 09:45 PM
  #292
wagon50's Avatar
wagon50
Default my dyno
06 Night Train 10.25.1 se pistions .35 head gaskets 585g ss cams thunderheader stage 2 heads from VEE Twin were Kirby worked his magic on my heads race tunner bike made 104 hp 104 ftlbs this is through a stock tb and stock injectors clutch started slipping at upper rpms in 4th gear let me know what you think
Old May 1, 2010 | 11:12 AM
  #293
NightTrain4Al's Avatar
NightTrain4Al
I have an 09 Night Train
Screamin Eagle Heavy Breather
Vance and Hines Big Radius 2 into 1
Screamin Eagle EFI Super Tuner, S.E. Pro
My max power = 72.9HP
My max torque = 87.52
The dyno paperwork says "Dynajet Winpep7"
CF: SAE
Smoothing: 5
Temp that day was 79 degrees and 29% humidity
Old May 2, 2010 | 08:07 PM
  #294
03hdfatboy's Avatar
03hdfatboy
Cant find my dyno sheet I have looked everywhere.. but here is my #'s
Stock 88ci 64hp/69tq
My current build
J.E.T Heads/SE HTCC Intake
KB 10.5:1 pistons/Head Quarters 0033-G
S&S gear drive kit/SE adj. Pushrods/PC III USB
Bassini RoadRage/Stage II ECM
109hp/114tq
My bike is currently at Kendall Johnson Customs getting a Baker OD6 and after talking to Stephen and have decided to go with a 117ci.. I WILL be calling him first thing in the morning to get that ball rolling
Old May 3, 2010 | 01:21 PM
  #295
kentucky boy's Avatar
kentucky boy
Stage I
2007 fxstc
Rhinehart crossback exhaust
Se 211 cams
Se race tuner
89 HP 98 ft lbs torque
Old May 3, 2010 | 02:03 PM
  #296
NCTURBOS's Avatar
NCTURBOS
My current build
109hp/114tq
Are you dead set on using KJC?? Not to but they did me pretty wrong on a build about 3-years back. I wouldn't recommend them to anyone...
K.
Old May 18, 2010 | 10:21 PM
  #297
oct1949's Avatar
oct1949
For U guys that have lost Ur sheets,, U can go back to the tuner and have them print U up a new one....
Old May 19, 2010 | 12:38 AM
  #298
03hdfatboy's Avatar
03hdfatboy
I plan on retuning mine when it is back together.
Old May 19, 2010 | 01:34 AM
  #299
03hdfatboy's Avatar
03hdfatboy
K.
So far they have been pretty straight forward with me, I told 'em ahead of time what I could spend.
When they got my bike appart they found a few issues.. my crank shifted and done some damage so the 117 is outta the question, now I'm doin a darkhorse crank and new timkin bearings, oil pump etc.
Oh well... I was happy with my HP anyway. Gonna have Zack retune the powercommander when he is done.
Old May 19, 2010 | 11:16 AM
  #300
07FXTBi's Avatar
07FXTBi
6th Gear
Default dyno numbers from the other side of the pond!!!!
these are my numbers at the moment. just a run,not a tune.....
the red lines are before when i had a problem and finally found by using
bub stealth baffles in a set of bub jug huggers strangled the motor. quite suprised
i didnt blow it up!!!.
changed them to a set of khromeworks AR100's 2-2 stepped and the diference is instant!!!
2007 Night Train
103" using wiseco dished pistons
red shift 575's
K&N filter
khromeworks AR100 2-2 exhaust
PCV retrofit from fuelmoto
stock heads
84.75hp
92.68tq
Attached Thumbnails "DYNO" Numbers For SOFTAILS-power.jpg   "DYNO" Numbers For SOFTAILS-torque.jpg
