"DYNO" Numbers For SOFTAILS
Old Jul 23, 2009 | 07:12 PM
  #171
beaureed445's Avatar
beaureed445
I must seriously be an idiot. I have my run in pdf format, but can't upload it. Too large...and I don't know how to resize it to fit. Any suggestions?
Old Jul 23, 2009 | 09:20 PM
  #172
kkinderen's Avatar
kkinderen
Open it and size it on your screen. Then take a screenshot (alt+print screen). Then paste it into a program like Paint and save it as a jpg file. It should be small enough. Hope that works for ya.
Old Jul 23, 2009 | 09:40 PM
  #173
beaureed445
Ok, after many failed attempts, I'm just took pics of the sheet....I realize that you probably can't see the run conditions, but here they are:
1/14/09 Run Conditions: 74.77*F, 29.26 in-HG, Humidity: 6%, SAE: 1.00
Max Power: 98.00 Max Torque: 109.20
'07 FXST, Baisley Super Stock Heads (1.94 intake, 1.63 exhaust; 82.3 cc chambers)
Wood TW6G7 cams, D&D Fat Cat w/ standard baffle, tuned with PCIII
Attached Thumbnails "DYNO" Numbers For SOFTAILS-dyno1.jpg   "DYNO" Numbers For SOFTAILS-dyno2.jpg
Old Jul 24, 2009 | 12:10 AM
  #174
oct1949's Avatar
oct1949
Originally Posted by jd8181
what in the heck is up with the lines on your dyno sheet??
If U look at the smoothing # its zero, thats way it was jumping all over..usually its 5.
Old Jul 25, 2009 | 12:24 PM
  #175
Troy L's Avatar
Troy L
Default 2009 Rocker C Stage 4++ 119 RWHP..
many many mods...
blue is the fastest..
Old Jul 25, 2009 | 04:13 PM
  #176
jd8181's Avatar
jd8181
Originally Posted by Troy L
many many mods...
what are you the "many many mods" ??? and what is the tq??
Old Jul 27, 2009 | 01:59 PM
  #177
Troy L's Avatar
Troy L
103 ci
SE 110 + heads - ported
SE 10.5 high compression pistons
SE 58 mm throttle body
SE 260 cam
SE intake - ported
Bassani stepped Road Rage 2 into 1 (short)
SE Push Rods
4.9 injectors
SE Heavy Breather
.030 cometic head gaskets
SE Super Race Tuner
Dyno tuned by Gil Nevarez @ NRP (Las Vegas)
119 RWHP / 113 FT LB... in 100+ degree weather with a corrected altitude of 6000 feet...
Old Jul 30, 2009 | 12:24 PM
  #178
coatit's Avatar
coatit
Just a basic stage #1 on factory 88 CI
Numbers after my first tune on the PCIII USB
Stats in signature
Old Jul 30, 2009 | 05:23 PM
  #179
jimmy-six's Avatar
jimmy-six
Stage II
1991-80 inch, 9.5 to one, CC EV10 cam, True roller rockers, SE air cleaner, Thunderheader, Killer Products CV Carb, 81 HP 88 TQ @ 4950 RPM
Old Jul 30, 2009 | 07:17 PM
  #180
SEDELUXE's Avatar
SEDELUXE
heres my 120 dyno
Attached Thumbnails "DYNO" Numbers For SOFTAILS-120buildsae.jpg   "DYNO" Numbers For SOFTAILS-120buildunc-1-.jpg
