"DYNO" Numbers For SOFTAILS
Old Apr 17, 2012 | 03:41 PM
  #651
harleytuner's Avatar
harleytuner
Originally Posted by L.F.O.D
Harleytuner what's your opinion of the screamin eagle 204 cam for a stock 103 with a fatcat 2-1 exhaust?
Thanks!
The 204 is aliright, but i'm still partial to the 251. The 251 is alot like the 255 but it caries the torque alot longer, it still comes in down low like the 255, but it carries it throughout the RPM range longer. The 204 is a decent cam in a 103 as well, but the torque will coem in later and drop off earilier than the 251. The Andrews 48H would be a good choice as well for a 103 with stock heads.
Old Apr 17, 2012 | 09:34 PM
  #652
Shiloh65's Avatar
Shiloh65
2011 Heritage; 96 CI, Woods 777 Cams, Cycle Shack 2" M Series Staggered Duals; PC V.
78.77 HP and 92 TQ prior to cams.
92.8 HP and 95.9 TQ after install.
Old Apr 18, 2012 | 03:14 AM
  #653
VEHLAon48's Avatar
VEHLAon48
That is unreal just with a cam?
How do you find it on the road? Big difference
Old Apr 18, 2012 | 06:46 AM
  #654
Leadbelly's Avatar
Leadbelly
WILD THINGS, heads, dome pistons,cams,S&S cam drive.,95 CI.
Old Apr 18, 2012 | 02:53 PM
  #655
Shiloh65's Avatar
Shiloh65
Big difference on the road. It runs like a raped ape. Every time I fire it up and take off I have a **** eating grin, it is that much fun to ride.... Doesn't help the mileage though The bike runs like it should have from the factory. I can feel the cams kick in around 2700 rpm but they really shine at 3500 rpm. It's fun hitting 85 in 3rd gear on the freeway onramp.
The Indie that did my cams and dyno says with Screaming Eagle ported heads, and a big bore kit with forged pistons, and 10:1 compression I should be able to get a minimum of 120 hp; even more with a bigger throttle body.
Old Apr 21, 2012 | 04:04 PM
  #656
AZRenegade's Avatar
AZRenegade
2008 Heritage 211 cams, 103 BB, Thunderheader, Pro CNC ported heads. 99hp/106tq
Old Apr 22, 2012 | 12:56 AM
  #657
tunaman's Avatar
tunaman
Dyno'd by Bob Lobenberg at RC Cycles:
Hillside 107" with proprietary 10:1 Wiseco flat-top pistons, Hillside 'stage 1' headwork with 1.90" intake valves, Andrews 31h cams, HPI reworked stock throttle body (ported/polished/bored to 48mm) with stock injectors, V&H ProPipe BP 2:1
Ended up with 105hp and 114 pounds of torque for this mild build.
Roger
Old Apr 26, 2012 | 05:47 PM
  #658
dbritsch's Avatar
dbritsch
Stage II
Hello to everyone,
This is a great forum that I have been reading non-stop. Figured I should sign up and share when I can.
I have a 2012 Fatboy with the 103. Stock dyno was 80/100 at HD of Salt Lake ( so 4500 altitude). Added a 255 Cam, SERT, Screaming Eagle High flow Filter, and Rinehart Cross backs, and dyno was 85hp/105tq.
Is this to be expected? It was tuned by HD salt lake, and is obviously still under warranty with 950 miles.
Thanks
Old Apr 27, 2012 | 06:59 AM
  #659
VEHLAon48's Avatar
VEHLAon48
Originally Posted by dbritsch
Hello to everyone,
Thanks
Does'nt make sense? Just to make things clear so you had 80/100 on factory standard right?
You must be getting atleast another 10/10 just by adding sert, rinehart n heavy breather . forget the 255?
Somethings wrong somewhere?
Old Apr 27, 2012 | 03:27 PM
  #660
dbritsch's Avatar
dbritsch
Stage II
VEHlaon48
Your post got me thinking so I called the service guy. The dyno run that I thought was stock was actually a pre-SERT tune baseline. Soooo, I find out that the dude ran the dyno with Cam, pipes, and air filter. Then he tuned it with the SERT and got the second numbers. Bottom line is I don't know what it had stock. Now I guess it does not matter, because my numbers are 85/105 and I will go from there!
Thanks
