"DYNO" Numbers For SOFTAILS
Old Nov 9, 2012 | 09:24 PM
  #751
sstud's Avatar
sstud
Cool my 02 softail
95 cubic inch
kb flat top pistons
bigger valves
decked head
port and polished heads
06 dyna throttlebody and injectors (bigger better injector spray)
python staggered duals
se air cleaner
hd race tuner
98hp 103tq
oh and hd 251 cams
Old Nov 12, 2012 | 06:50 AM
  #752
txphatboy's Avatar
txphatboy
Stud, your build sounds similar to mine, except I am not sure of specs on 251 cams. Can you post Dyno sheet - I would like to see the power curves with the injectors and exhaust? I actually have numbers very similar - 96 hp and 102 ft lbs, but I am not real happy with the dip I have down low. Thanks
Old Nov 12, 2012 | 07:00 AM
  #753
NVS's Avatar
NVS
sstud
those are nice numbers would love to see your sheet
Old Nov 27, 2012 | 01:35 PM
  #754
wagon50's Avatar
wagon50
SStud put a good 2into1 on it and you will be over 100hp
Old Dec 5, 2012 | 02:59 PM
  #755
gaza246's Avatar
gaza246
6th Gear
Can't upload my dyno chart. FLSTN with a 120r that has a nos kit.
119.69 hp 110.88 Torque
147.38 hp 143.90 Torque on NOS
Old Dec 5, 2012 | 05:51 PM
  #756
wagon50's Avatar
wagon50
I figured you would see higher numbers from the 120r
Old Dec 5, 2012 | 06:42 PM
  #757
harleytuner's Avatar
harleytuner
I'd really like to see your sheet. I'm not going to criticize your build to much without seeing your sheet, butyour numbers seam pretty low to me, especially if they aren't showmn in SAE. I'm sure it's a blast to ride (especially with the spray) but I can get 119 HP and 110 HP out of a 107 for a fraction of what you spent. PLease try to upload your sheet or PM me and i'll get you my e-mail so I can upload it.
Old Dec 6, 2012 | 11:52 PM
  #758
windycity's Avatar
windycity
5th Gear
Default 2009 crossbones 96 to 103
Getting ready to do SE stage 4 kit on stock bike except for 2 into 1 rhinehart high performance exhaust and RSD air cleaner already on. Should i just do stage 2, and can you tell the difference. deciding if stage 4 is worth the $
Thanks
Old Dec 7, 2012 | 06:52 AM
  #759
imrotton2's Avatar
imrotton2
do the stage 4.... nite and day difference
Old Dec 7, 2012 | 12:41 PM
  #760
wagon50's Avatar
wagon50
I just figured that 7k would get you a little more power
