"DYNO" Numbers For SOFTAILS
Old Apr 16, 2013 | 12:24 PM
  #851
skooter2000fb's Avatar
skooter2000fb
Default Dyno #'s
95" Dave Mackie Megasphere
103hp
110 f lbs torque
Old Apr 16, 2013 | 01:43 PM
  #852
wagon50's Avatar
wagon50
Skooter what cams?
Old Apr 16, 2013 | 01:52 PM
  #853
Lone wolf lo 10's Avatar
Lone wolf lo 10
Originally Posted by groovna
When you look in the pipe from the back there is a plate in there so its not straight through, that was drilled out.
Thx for the info enjoy that rocket
Old Apr 16, 2013 | 10:57 PM
  #854
Klrdog's Avatar
Klrdog
No much hp but I see some torque...
Old Apr 17, 2013 | 07:25 AM
  #855
TheTroupe's Avatar
TheTroupe
Klrdog
Your motor is starving for air (coming in and/or going out) from 4000 and up.
Old Apr 17, 2013 | 08:22 AM
  #856
Klrdog's Avatar
Klrdog
ok.. How fix that? Thanx
Old Apr 17, 2013 | 05:37 PM
  #857
TheTroupe's Avatar
TheTroupe
Displacement? Any other work like heads/valves/??
Old Apr 17, 2013 | 11:21 PM
  #858
Klrdog's Avatar
Klrdog
No..stage 1 and 255 cams.
Old Apr 18, 2013 | 08:23 AM
  #859
TheTroupe's Avatar
TheTroupe
Air - Fuel - Ignition That's what we have to work with.
The air fuel ratio is good but that does not mean there is enough air getting through the air filter, you are sure that it has an SE breather.?.
Now lets ask questions of the cam installation. Is the cam off a tooth? I learned recently that the bike will still run, but poorly, with the cams off timing by one tooth. Did they use adjustable push rods? If so then did the let them bleed down properly before adjusting?
Are the O2 sensors still in place? is the EFI tuner the correct one for a 2013?
Finally an old fashion check of the spark plugs might reveal more information.
Old Apr 18, 2013 | 05:29 PM
  #860
Klrdog's Avatar
Klrdog
Ill research all of that. How can you tell from the dyno sheet that it needs air?
