"DYNO" Numbers For SOFTAILS
Old Apr 9, 2018 | 07:23 PM
  #1351
FATTYLO88's Avatar
FATTYLO88
3rd Gear
Default 2013 Fat Boy Lo
Still working on it at this point S.E. Heavy Breather, Stage 2+ heads, 1.9 &16 Valves, .650 springs, S&S push rods & lifters, Combustion chambers reduced to 83.5 cc to obtain 11:1 compression, intake opened up to 1.8 (with ramps) for the 55MM HPI throttle body with Fueling 4.9 injectors, 107" cylinders with Carrillo pistons, Fueling .594 reaper cams,V&H Pro Pipe with a modified baffle,Barnett performance clutch, AIM variable pressure plate, Power yup it is a hand full for a FAT ****!!
just put 30 fat spokes on it with twista front spokes
Both my Scoots
The Dark Knight (FAT LO)
The White Knight (Mr. Springer)
Vision Tune.
Old Apr 30, 2018 | 03:15 AM
  #1352
robatrak's Avatar
robatrak
Both my Scoots
Vision Tune.
Hi,
Can you tell me how you are managing with the right-hand bends, I seem to be scraping the road before my floorboards
Old Jul 19, 2018 | 10:16 AM
  #1353
Donald Mazz Derby's Avatar
Donald Mazz Derby
Dyno tune final numbers in red
This is just at 97" with 585 cams and mikuni carb hsr42. Plan on kicking it to a 120" soon
Old Jul 23, 2018 | 04:07 PM
  #1354
baloot-boy's Avatar
baloot-boy
Can you feel that torque dip? You need to up the compression for those 585s.
Old Jul 24, 2018 | 10:39 AM
  #1355
txphatboy's Avatar
txphatboy
I am no tuner, but that AFR graph looks all off. How much time/how many runs were made during this Dyno?
Old Jul 27, 2018 | 06:56 AM
  #1356
98hotrodfatboy's Avatar
98hotrodfatboy
Definitely not tuned properly.....
that curve should pop 100 lb/tq @3k....
Old Jul 30, 2018 | 07:05 PM
  #1357
Pyro451's Avatar
Pyro451
Default 2016 FLSTFBS +117 kit Dyno Sheet
Just tuned with SEPST (SERT) and 117 kit (injectors, TB, 259E cams, etc) and SE Cam plate with high volume oil pump. Cobra 2-2 exhaust and 58mm backplate added to the stock Ventilator Elite air cleaner. I expected more from this build. Maybe lost too much due to 2-2 vs. 2-1 exhaust? Comments welcome.
Old Jul 30, 2018 | 07:18 PM
  #1358
Donald Mazz Derby
problem is actually being pig rich right there i needed to drop my needle but ran out of time.
Old Jul 30, 2018 | 07:19 PM
  #1359
Donald Mazz Derby
compression is 10.75:1
Old Jul 31, 2018 | 06:22 AM
  #1360
harleytuner's Avatar
harleytuner
looks like you could drop a main jet and cut back the accelerator pump. Needle effects cruising AFR and dropping it will make It richer at cruising
