"DYNO" Numbers For SOFTAILS
Old Apr 18, 2013 | 07:24 PM
  #861
TheTroupe's Avatar
TheTroupe
Originally Posted by Klrdog
Ill research all of that. How can you tell from the dyno sheet that it needs air?
At 3000 the torque begins to dive, with a 103 and the 255 cams it should hold steady at least to 5k.
The peak horse power is pathetic.
The AFR (air fuel ratio) is correct so the tune is right for the air that is getting into the engine. either the ignition timing is off or the valves aren't letting in enough fuel/air to run the engine at higher rpms.
Old Apr 20, 2013 | 04:40 AM
  #862
madjeeper's Avatar
madjeeper
Default Here is mine
Just got my 08 FLSTC tuned today. How does it look to you guys? I have Arlen ness stage II big sucker. A Cobra Power Pro HP 2-Into-1 Exhaust. Using a PC III USB as a programer. When I used a temp map first two days I felt more TQ right away and bike felt like it was cooler too. Had bike tuned to day and it feels hot again and not as torque.
Check my map out.
Old Apr 20, 2013 | 02:27 PM
  #863
madjeeper's Avatar
madjeeper
Default Anyone?
Check my map out.
Anyone going help a guy out?
Old Apr 20, 2013 | 07:51 PM
  #864
asa1199's Avatar
asa1199
Default Dyno 4-19-13
2013 Heritage SE Stage 1 A/C V&H Straightshot Slip-ons w/ Quiet Baffles
Any Opinions or Thoughts?
Old Apr 21, 2013 | 11:30 AM
  #865
TheTroupe's Avatar
TheTroupe
Do 2013 103Bs have their catalytic converters in the header pipe?
Old Apr 21, 2013 | 08:57 PM
  #866
asa1199's Avatar
asa1199
No Cats
Old Apr 23, 2013 | 09:51 AM
  #867
Kschrods's Avatar
Kschrods
Just had mine done last week, 89' FXSTC, S&S carb and Rinehart Churchills, rest of the motor is stock. 70HP and 83 FPT, not bad for 24 years old and 31K miles.
Old Apr 23, 2013 | 12:19 PM
  #868
madjeeper's Avatar
madjeeper
Default ???
Just got my 08 FLSTC tuned today. How does it look to you guys? I have Arlen ness stage II big sucker. A Cobra Power Pro HP 2-Into-1 Exhaust. Using a PC III USB as a programer. When I used a temp map first two days I felt more TQ right away and bike felt like it was cooler too. Had bike tuned today and it feels hot again and not as torque.
Check my map out.
Can anyone tell me what they think of my DYNO read out?????
Check it out on page 87
Old Apr 23, 2013 | 12:41 PM
  #869
madjeeper's Avatar
madjeeper
Default How does this look???
Here is my Dyno run from the weekend. Can anyone tell me is this any good? I have a 2into1 comp header. Big sucker II AC. #1 down load. Tuned with a PCIII USB.
Is 71HP and 83TQ good for a stock motor with just bolt on's?
Old Apr 23, 2013 | 06:07 PM
  #870
Raccerx67's Avatar
Raccerx67
your VE tables must be good cause your AFR line on bottom of the print is nice and flat. Tha's a good thing. If it's running hotter now my best guess it was running rich prior to your tune.Graph looks good and in the area it should be. Did not see what tuner your using but changing the closed loop bias tables to something in the 650-700 range could help cool a touch. Also timing tables can affect engine temps. If its a Lambda map you can adjust those for cooler running. Talk to your dyno guy and see what he says....
Doug
