"DYNO" Numbers For SOFTAILS
Old Jan 4, 2013 | 06:45 AM
  #771
FatBoyTig's Avatar
FatBoyTig
txphatboy, I think you may be on to something - power at the crankshaft vs power at the wheel.
DD&Weevil, it's a 96CI engine (stock) and the spec is from the HD website. The map is tailored by dynojet for 2010 Fatboys with stage 1 and D&D fatcats. I've tried other maps from fuelmoto which had similar map numbers and performance but were not dynojet tested.
Old Jan 4, 2013 | 07:31 AM
  #772
BlackSpecial's Avatar
BlackSpecial
Has FuelMoto seen your latest dyno sheet? It seems if they took a look at the a/f ratio they would be able to fatten it up where needed.
Old Jan 4, 2013 | 08:21 AM
  #773
Weevil's Avatar
Weevil
On a stock 96" motor, 68 hp/82 tq SAE is about average based on dyno testing at the rear wheel. With a stage 1 download and canned map, set up very similar to your bike, it still should be somewhere in the 70+ hp/80+ tq range.
I'm sending you a link for Docs Performance Tuning in Minneola, Florida. He's, arguably, one of the best tuners in the United States.
Scroll down to the feedback with the red lettering. Tuning a bike set up pretty close to yours, he was able to squeeze out 92.12 tq & 76.75 hp SAE. He was tuning using a TTS vs. a PCV.
http://www.docsperformancetuning.com...Feed_Back.html
I can also refer you to other site(s) that will verify the numbers here. I'm sure if you decided to get a custom tune your #'s would increase. By how much? And you're lucky to live in an area where there are some darn good tuners. A few that come to mind is Jim Kennedy (aka strokerjlk) at Paradise Performance in Mattoon, IL, (217)273-6847, Valley Racing in Beecher, IL, (708)946-1440 and Engines by Otto in Sugar Grove, IL, (630)466-3900. The only fly in the ointment is if they tune using the PCV or not.
Old Jan 15, 2013 | 03:21 PM
  #774
zipperhead86's Avatar
zipperhead86
6th Gear
i got 104hp 116torque. 103 with 211 cams head work .30 cometic dome forged pistons 1.762 rockers dd fatcat
Old Jan 18, 2013 | 05:12 AM
  #775
goats's Avatar
goats
anyone here know the difference between the andrews 48h and 26h cams ?
i am leaning towards the 26 but would like to know the difference before i pull the trigger.
dyno numbers are cool but seat of the pants is where its at for me
Old Jan 18, 2013 | 07:56 AM
  #776
bobbyjoes's Avatar
bobbyjoes
2004 heritage softail 104 all bore (4" stroke 4.075 bore) WFO heads, S&S 585 ez Fatcat standard baffle,got it posted on other forums ,thought post it here
Old Jan 20, 2013 | 08:31 AM
  #777
Weevil's Avatar
Weevil
Congrats on the nice build. Second all bore 104" dyno chart I've seen. Both with great numbers (the other = 116tq/118hp SAE). Surprised you don't see more around.
Gotta love that long flat torque line.
Old Jan 22, 2013 | 08:53 AM
  #778
SweetPee's Avatar
SweetPee
2006 Deuce 88ci.
Added:
Complete T-Man Pro Touring Elite 98" Kit
625 T-Man cams
Manual Compression releases
HPI 51mm TB with 1.760 inlet
HDSE 4.9GPS fuel injectors
HDSE cam plate w/hydraulic tensioner & HF oil pump
HD oil cooler
HD clutch spring
HDSE rocker supports
HDSE roller tappets
HDSE roller rockers
HDSE tapered adjustable pushrods
Supertrapp SuperMeg 2 into 1 with 22 disks and open end cap
HDSE Pro Tuner
It was tuned for ridability & longevity and not every last drop of power it could produce.
Netted 101HP & 99TQ
Old Jan 22, 2013 | 11:15 AM
  #779
applesith's Avatar
applesith
Stage III
yno's How much are the dyno's coing for at a HD dealership? Is is wise to first do the Stage 1 download, then the dyno? Or does it matter. I have a stock 2006 Heritage. Any advantage to doing both, one, or none?
Old Jan 22, 2013 | 06:52 PM
  #780
bobbyjoes's Avatar
bobbyjoes
so if you max out your tq and horse power on a dyno its not ridable or last long ?
