"DYNO" Numbers For SOFTAILS
Old Jan 1, 2012 | 10:24 AM
  #571
harleytuner's Avatar
harleytuner
Originally Posted by tps77
Just had new pipes, se heavy breather installed on flstb 2011 and purchased se pro super tuner and had ride dyno. Was told 4 hrs for dyno but that they would kick back money if it took less time for dyno ,I have the results they gave me from dyno my question is how can you tell how many runs did they do on bike . Don't mind paying just don't want to get f----d and would also let me know who kind of people I'm dealing with. Thanks ahead
If your tuner didn't change teh file name, you can see what run number he printed, that should give you an idea. (if he has a dynojet dyno) look at the bottom of your sheet, where it has your info and the run conditions. It'll start with runfile_0**. When they start the run it is default at runfile_001 and creats a new number (in sequence) for each additional run. unless the tuner renames them. If he printed a befor (as received) run and an after run, you can look at the time stamp for each run and get an idea of how long the bike was on the dyno.
Old Jan 6, 2012 | 10:17 AM
  #572
oct1949's Avatar
oct1949
The sheet below was when they tweeted my tune after cam install.
At the bottom it says.
tom dyno run _ 008 - means they make 8 runs when this sheet was printed.
If U ask for a copy of the 1st run and the finial sheet U'll see how many runs they made and the time between them plus time for setup will give U total time.. But sometimes a tuner will have to attend to other things during the job. So the real time spent on U bike may not be what the difference thats shown between them.
For example on this tune I was told he started at 7:00 AM on my bike and finished the last one at 1:39. PM, but he didn't spend 100% of those 5 1/2 hrs on the bike tuning it.
I didn't ask for the first sheet this time either because it was on their dime because they were tweeking the bike from an earlier tune
Old Jan 6, 2012 | 05:28 PM
  #573
tps77's Avatar
tps77
Default dyno
Thanks for responses,Ill know what to ask for and look for on next motor upgrade happy safe and new year
Old Jan 10, 2012 | 11:45 AM
  #574
HDCrossbones09's Avatar
HDCrossbones09
All my specs are in my sig. My builder said I really need a 58mm tb and to open up my quiet baffle but Im still super happy with the numbers. He was really close with the can map. If your wondering what the arrow is for its where he set my revlimiter on the base break in map.
Attached Thumbnails "DYNO" Numbers For SOFTAILS-2012-01-07-18.13.45.jpg   "DYNO" Numbers For SOFTAILS-2012-01-07-18.15.09.jpg
Old Jan 10, 2012 | 11:46 AM
  #575
HDCrossbones09
Not sure why but it double posed the same thing I just said.... maybe im to click happy sorry
Old Jan 12, 2012 | 11:59 AM
  #576
oct1949's Avatar
oct1949
104 square, That IMO would be a power house, Much more and U'll need to think about beefing up the bottom..
Great build.
Old Jan 14, 2012 | 07:39 AM
  #577
Joker_Hal's Avatar
Joker_Hal
Looking for some advise. I've got a 2010 Fatboy. Although I've made several changes to enhance the comfort, and safety, nothing has been done to improve performance. I'm looking for suggestions on exhaust and fuel controller. Given the choice between performance and sound, I'll take performance any day.
Old Jan 19, 2012 | 02:58 PM
  #578
TheTroupe's Avatar
TheTroupe
2003 88 ci
Stage-1 Intake with K&N filter
SE 204 Bolt in cam
2:1 SuperTrap pipes.
Powercommander III
Dyno Tuned
88 ft/#s of torque & 81 HP
Over 80 ft/#s of torque from 2300 through 5250
Smooth HP curve.
What more could you ask for from an other wise stock 88ci.
Otherwise stock = No head Shaved, no high compression pistons, no valve work, no big bore kit etc...
Last edited by TheTroupe; Mar 26, 2012 at 03:12 PM. Reason: To make peace with grumpy folks
Old Jan 19, 2012 | 04:05 PM
  #579
BlackSpecial's Avatar
BlackSpecial
Smooth HP curve.
What more could I ask for from an other wise stock 88ci.
Not to pick nits, but the bottom of the dyno sheet and your sig don't say "stock" to me.
Must be a fun scoot tho!
Old Jan 19, 2012 | 04:13 PM
  #580
TheTroupe's Avatar
TheTroupe
Please delete all of my posts.
