"DYNO" Numbers For SOFTAILS
Old May 11, 2014 | 08:40 AM
  #1011
custom_fatboy's Avatar
custom_fatboy
Originally Posted by SkullyChick
The hubs had some work done for me as a present while I'm deployed...sent me this. I don't know how to read it, but would like to learn. Anyone care to analyze?
no problem, you now have 72.73hp and 87.57 torque wich is ok, i also like the way your curve goes, seems like if u want power keep it between 3-4k rpm
Old May 13, 2014 | 10:40 PM
  #1012
SkullyChick's Avatar
SkullyChick
Thank you!
Old May 16, 2014 | 08:42 AM
  #1013
Microdoted's Avatar
Microdoted
'14 breakout
103
heavy breather
v&h big radius 2-2
BCT baffles
SE programmer
SE 259e cam
96.21 hp
101.74 torque
Old May 17, 2014 | 07:34 PM
  #1014
swilcoxon86's Avatar
swilcoxon86
6th Gear
Default 2013 Softail Deluxe Dyno Sheet
2013 FLSTN. Only performance modifications on the bike are the Samson 33" Fish Tails (Non-Baffled), and a SE Stage 1 Air Cleaner (Under Stock Cover). Bike was tuned using the HD Tuner.
MAx Power is:
HP: 77.63 TQ:98.14
Old May 26, 2014 | 05:33 PM
  #1015
Olsen185's Avatar
Olsen185
Originally Posted by cruzer01
103 SE with SuperTrapp 2:1
For some reason I didn't get the before #'s just added the PCV and dyno by Speeds Performance out at Laughlin, NV in April of 2012. Seems like the #s are comparable to most here. Lost gas milage for some reason, thought it would make it better. Any ideas?
Did you notice any difference after the tuner?
Old May 26, 2014 | 07:17 PM
  #1016
cruzer01's Avatar
cruzer01
Olsen,
The bike always seems to have plenty of power, what I did notice was that I was having some popping when decelerating. That poping went away after adding the tunner and the dyno. The milage went down from 40 mpg to 36 mpg. As far as power, it seems to have improved but hard to tell since I really don't open up the throttle a whole lot. The guys at the speeds said it was a significant power improvement.
Old May 26, 2014 | 07:55 PM
  #1017
Olsen185's Avatar
Olsen185
Olsen,
Good to hear, that was my next investment, well right after I replace my drive belt. Do you own the tune, or is it their work product? Just wondering if there was anyway to use your tune as a baseline.
Erik
Old May 27, 2014 | 11:08 PM
  #1018
cruzer01's Avatar
cruzer01
Erik
Erik,
No sure how I would get it to you? When you get your PCV it comes with a disk and a computer cable. I did download my tune but not sure how I could get it to you. Maybe someone here has knowledge of that.
Old May 27, 2014 | 11:19 PM
  #1019
Olsen185's Avatar
Olsen185
Erik,
Ok so you downloaded a pre-canned tune from their tune library? I was under the impression you had a dyno tuneing session.
Old May 27, 2014 | 11:23 PM
  #1020
cruzer01's Avatar
cruzer01
No, I did have a dyno done, I then saved it from the bike to my laptop with the software and cable that it came with.
That was the dyno sheet you saw on my previous post.
