"DYNO" Numbers For SOFTAILS
Old May 28, 2014 | 01:48 PM
  #1021
protocolgeorge's Avatar
protocolgeorge
6th Gear
Default Just got mine back last night....
Just got my final dyno tune completed yesterday.
2010 Fatboy Lo
S&S 106 Big Bore Kit
S&S 585CE Easy Start Cams
SE Ventilator Intake
SE Race Tuner
Vance & Hines Big Shots Staggered
BDL 2" Open Primary
103.8Hp 113.81Tq
It pulls like crazy, high recommended configuration.
Old May 31, 2014 | 06:04 AM
  #1022
Boost's Avatar
Boost
Originally Posted by SkullyChick
The hubs had some work done for me as a present while I'm deployed...sent me this. I don't know how to read it, but would like to learn. Anyone care to analyze?
This who I think it is.......
Dyno looks good but the Air Fuel Ratio (AFR) is pretty lean for a Wide Open Throttle (WOT) pull. Me thinks there is more power in there....
Old Jun 1, 2014 | 09:31 AM
  #1023
ghoticov's Avatar
ghoticov
2010 Fatboy Lo
SE Race Tuner
BDL 2" Open Primary
103.8Hp 113.81Tq
Get a good 2:1 pipe and you can get rid of that flat spot in the torque curve down low. Ask me how I know. Lol
Old Jun 2, 2014 | 06:42 PM
  #1024
protocolgeorge
6th Gear
Thanks. Thought about it, but I really like the look of the big shots. Might do the s&s 89cc head and SE 58mm throttle body for next season.
Old Jun 2, 2014 | 06:54 PM
  #1025
timber0472's Avatar
timber0472
The dealer said their printer was down so I have to go back to get the print out but my numbers didnt seem right. 78hp and 86.5 tq. Seems weak to me especially with all the work I did. Guy said my Bub 7 True duals are killing me, but I'm not sure if I agree yet. Thinking of switching PCIII to Thundermax. Any advice on better performance upgrades? (besides 2 to 1 pipe!)
2003 heritage tc88:
Ported hi flow heads
Old Jun 12, 2014 | 12:12 AM
  #1026
oct1949's Avatar
oct1949
Timber How does she feel... a lot stronger or a little bit..
Dyno number's can be all over the place pending on who, how, and went the tune was done...
As far a just #'s,, yes for all the work you did A good tune should have IMO netted better numbers. but?????
Go back to the OP (First post) in this thread and you'll see my numbers....
Old Jun 12, 2014 | 04:30 PM
  #1027
timber0472's Avatar
timber0472
The bikes performance honestly was the same as before the dyno. The only thing I had wad a canned map from pc3. The dyno made no noticeable difference. But my problem seems to solved now. I just purchsed a thundermax. Best investment ever! Bike is performing better than it ever has. I used their suggested map and then tweaked it myself using their software. I pulled the front tire up a couple inches. Never have been able to do that. I would be very interested in seeing what the numbers are now. Regardless im very satisfied with the results of the butt-meter now. Thanks for your reply.
Old Jun 16, 2014 | 10:15 AM
  #1028
oct1949's Avatar
oct1949
Timber -- Glad to hear you're happier now.. Its sad, but there are dyno tuners out there that can't get/give people a good tune..
The wrench we had at our dealer was a 31 yr PHD master wrench with 15 yrs of doing dyno's who Still loved to work on bikes.
He wasn't the best in the country, but he was as good as it gets around here.
Too bad he just retired this spring. He was the only person the son and I would let touch our bikes engines.
I don't have any experience with any of the newer Auto-tuners.
Back in 07 the SERT was the best choice around here and I have never had a single issue with it.
Its only been touched once in 46k miles since the 1k service when installed and that was when I added the cams at 16K miles.
Hope all is well now with your new tuner....
Old Jun 18, 2014 | 10:57 PM
  #1029
Teufelhund's Avatar
Teufelhund
2007 FXSTC 8000 miles
SE Heavy Breather and SERT
V&H Big Shots
SE 103 kit w/SE 10.5:1 high comp pistons
SE 211 cams
112 hp / 126 torque
Will post the spec sheet as soon as I can find it.
Old Jun 26, 2014 | 11:54 PM
  #1030
GadgetBandit's Avatar
GadgetBandit
Had Rose on the dyno, yesterday. Piper Performance did a custom map for the Power Commander. I'm a happy camper. 77hp & 85ft-lb. It runs as smooth as the curves on the map.
'04 Heritage Classic 88B
Andrews 21N cam upgrade
Power Commander 5
B&B Fatcat 2:1
