Stage 1
Old May 11, 2009 | 02:18 PM
Rick14221's Avatar
Rick14221
Default Stage 1
Hi I have a stage 1 screaming eagle air filter and took the football air cleaner cover off and the bike, an 01 fatboy seems to have a lot more pep. Am I imagining this?
Old May 11, 2009 | 02:33 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Carbed or EFI?
Motors like to run a wee bit "Angrier" when they go from struggling to breathe through a restrictive element to able to breathe and suck in lots of air. You are not imagining it.
Pull a plug and see what color it is before you get to crazy. White = No Good.
Old May 11, 2009 | 02:40 PM
Rick14221's Avatar
Rick14221
It's carbed. Am I going to do any damage?
Old May 11, 2009 | 03:21 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
You should be cool. I put a high flow filter on my old Evo Heritage without any issues but I put in a new set of plugs and did a plug chop test to make sure it wasnt lean....
Dont try and add pipes and filter without rejetting. Just filter you should be OK.
Just make sure you aint too lean via checking those plugs.
Edit: You did put on just the SE high flow filter right???
Remember more air enters needs more fuel to go with it. I would rather be rich and safe than lean and on the edge. Make sure you check your plug coloration and maybe ask your local dealer if they have been bumping the jets when just doing the stage 1 filter without pipes. Lean = Hot. Hot = Bad.
Old May 11, 2009 | 04:58 PM
Rick14221's Avatar
Rick14221
Thanks Dude....Yeah I just pulled the football cover off and have already been running with V&H Big Radius...seems to have more pep and possibly idle alittle faster
Old May 11, 2009 | 06:57 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Are the original owner? Did you put the pipes on the bike? What jets are in it now?
If its jetted bone stock and you put the SE filter and the Big Radius on you will run lean as heck and quite possibly blow or severly damage your motor.
If you arent the first owner and bought it with the pipes its probably already jetted fatter.
I would address the jetting prior to riding the bike if it were mine and I liked it
Old May 11, 2009 | 07:53 PM
Rick14221's Avatar
Rick14221
I'm the second owner. Guy before me had the stage 1 and pipes done. I will pull a plug and take a look though. Bike runs great, I love the fatboy
Old May 11, 2009 | 08:10 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
You are gold. Its already stage 1 jetted. Thats why it runs better with the SE airfilter. Its jetted to be ran like that!
Now break bread with a photo Rick so we can see this Fat Beast of yens.
Old May 11, 2009 | 10:09 PM
oct1949's Avatar
oct1949
check plugs, or get a AF ratio check..
winchcable
Exhaust System Topics
May 24, 2011 07:18 PM
steve 55
Jun 27, 2010 03:00 AM
blackpullet
May 3, 2010 12:42 PM
gilmour68
Jun 22, 2007 10:53 PM
Chief101
Oct 15, 2006 08:17 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
