K+N Air Filter
Old Jun 26, 2010 | 07:56 PM
steve 55's Avatar
steve 55
Default K+N Air Filter
I'm just wondering, I don't know if this is right or not. I just bought a K+N air filter for my stage 1. It seemed to give a few more horses to my U.C.08. But, now it feels like its running hotter than before. I checked It out with the InfraRed thermometer, On the front cylinder it read 274*F on the rear cylinder it read 360*F This was right buy the spark plug. Am I doing this right or do I need to go get another tune? I would appreciate any advice I can get. Thanks
Old Jun 26, 2010 | 08:16 PM
artz's Avatar
artz
well...you are feeding more air to the motor and that is making it run hotter. Thats all I can say about that.
Old Jun 26, 2010 | 08:56 PM
steve 55's Avatar
steve 55
Default K+N filter
That's right It is getting more air, but is it getting that much more that I would have to have it tuned again? 360*F that's hot. But that is at the spark plug, Is that normal for the infaRed at that spot?
Old Jun 26, 2010 | 09:01 PM
artz's Avatar
artz
prob not, but if you added pipes into the mix, then you would.
If you added pipes and air intake (not just a filter),it would also prob run crappy. The computer can only re-adjust so much until you need to get a new tuner.
Old Jun 26, 2010 | 09:20 PM
dohadex's Avatar
dohadex
Question Stg 1 Filter
Were you running the stock H-D air cleaner before that?
Old Jun 26, 2010 | 09:50 PM
SteveO's Avatar
SteveO
The K&N could cause a short term lean condition. The newer bikes will eventually adjust for the increased air flow and maintain the lean and hot 14:1 F/A ratio. Takes about 30-45 minutes riding time and several starts for the ECM to adjust the F/A ratio. All the Harley stage 1 download does is change the RPM limiter to 6000, it does not change the F/A ratio.
Old Jun 27, 2010 | 12:31 AM
steve 55's Avatar
steve 55
Default K+N filter
Dohadex, I am running vance +hines true duels with ovels, s.e.air filter. sert tuner. everything has been on for 2 years except the K+N filter.
Old Jun 27, 2010 | 12:45 AM
steve 55's Avatar
steve 55
Default K+N filter
Good info, That's why I'm thinking It's got to be alright I rode two-up a couple hours in 90*F today. But still 360*F just don't look good do you know what I mean?
Old Jun 27, 2010 | 03:00 AM
ASPHALT WARRIOR's Avatar
ASPHALT WARRIOR
your running to lean ...u added more air but not more fuel
roadroids
Exhaust System Topics
Feb 6, 2011 11:24 AM
surf256
Apr 20, 2010 08:18 PM
langlois1
Jun 23, 2009 03:18 PM
Rick14221
May 11, 2009 10:09 PM
hangnman
Jan 27, 2008 02:10 PM
