Calling all FatBoy Lo Owners
Old Apr 26, 2017 | 10:16 AM
  #13651
Freak Show's Avatar
Freak Show
what's that, never heard of it. got a link?
Old Apr 26, 2017 | 10:29 AM
  #13652
Mother's Avatar
Mother
http://www.boardtrackerharleyonline.com/
Old Apr 26, 2017 | 10:36 AM
  #13653
Freak Show's Avatar
Freak Show
Just ordered the parts, 32 bucks cheaper than the HD website. Thanks Gents
Old Apr 26, 2017 | 10:45 AM
  #13654
Freak Show's Avatar
Freak Show
now i gotta find some good lights for the set. am also gonna change the headlight to that one from amazon that you showed me, Mother
when the kit gets here i'm gonna paint the trim rings, i don't want them being chrome
Old Apr 26, 2017 | 11:55 AM
  #13655
ILMFBL's Avatar
ILMFBL
Don't forget, pics or it didn't happen.
Old Apr 26, 2017 | 12:14 PM
  #13656
Freak Show's Avatar
Freak Show
Well that's gonna be a while. maybe a month or two.. i have a bunch of rides planned so i gotta find time in between that and normal crap
Old Apr 26, 2017 | 07:55 PM
  #13657
Gommee's Avatar
Gommee
Devil's Advocate
Dan
Since you are going for it, here is what you should look for:
1. Under the front (clutch side) of the tank, lift the rubber seal and look for a small connector hanging out in there. It has 2 wires, one is red and I believe it has a yellow tracer, the other is black. It is a switched power outlet that is meant to connect a fender tip lamp.
2. Pick up a harness from HD called "Independent Control Auxiliary Lamp Wire Harness Kit" Part #69200442. It is not really a kit, just a harness. It will give you a switched power source that is not controlled by the high beam and turns off when ignition is turned off and you won't accidentally kill your battery.
By using this to power your aux lights, you can have you aux lights on and your high beam at the same time. No cutting and soldering wires, Plug and Play!
The extra plug worked great to plug my GPS into. Had to get a connector and pins from HD to make that happen.
Old Apr 26, 2017 | 08:12 PM
  #13658
Freak Show's Avatar
Freak Show
alrighty. how much was the harness. did you get it from harley or somewhere else. i want to do this right for sure. i still gotta find some aux lights.
Old Apr 26, 2017 | 08:48 PM
  #13659
Gommee's Avatar
Gommee
Devil's Advocate
On the US HD site, $29.95
Do a search for the part # - 69200442
I refuse to cut wires. Something to screw up in the middle of nowhere!
Besides, the harness has an inline fuse. Extra protection!
Old Apr 27, 2017 | 07:02 AM
  #13660
Freak Show's Avatar
Freak Show
awesome, will look today
Just ordered it from boardtracker also. since it will come with my other order it was only 25 bucks.
