95" or 103"
Old Nov 8, 2006 | 07:05 PM
broke joker's Avatar
broke joker
Default 95" or 103"
hey guys i'am going to upgrade my engine this winter. but don't know what ot go with. I could go 95" s&s 510 cams, screaming eagle heads. Or just go with the 103" kit from harley. Need some help witch one will give me more power. Oh i ride a 05 springer classic if it helps.
Old Nov 8, 2006 | 07:33 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Default RE: 95" or 103"
I would lean toward the 103 and get cams and the heads. If your going to do may as well go BIG [8D]
Old Nov 8, 2006 | 08:02 PM
ChopperHammer666's Avatar
ChopperHammer666
I was looking into the same thing. I was told the 95 inch hot set up will get more power than the 103. The 103 is also considerably more expensive and requires machining. I don't remember the exact prices but the 103 was more than double the price of the 95.
Old Nov 9, 2006 | 12:09 AM
nikonf8's Avatar
nikonf8
you did not mention what year bike you are going to do this to if it before 07 i would forget the 103 this would mean splitting the cases and stroking the motor which is not recommended on the twin cam 88b. it would be noisy and run ruff and its not worth the price. the 95 big bore with cams and heads will do you right
Old Nov 9, 2006 | 12:16 AM
broke joker
05 springer classic. But i might switch to dave mackie 510 cams now i looked at the specs on them and they look really neat. Any first hand info on them would help.
Old Nov 11, 2006 | 01:52 PM
Cigar Aggie's Avatar
Cigar Aggie
Let me know how it goes, may do the same next year!
Old Nov 12, 2006 | 12:00 AM
AK_Hog_Herder's Avatar
AK_Hog_Herder
The 95 or 98 (available here) will give you the biggest bang for the buck.
The 95 with good cams and tune will give the largest gain. You don't see as much improvement from the 95 to the 103.
The 103 is a stroked 95.
Old Nov 12, 2006 | 01:06 AM
XfasteddieX's Avatar
XfasteddieX
01 heratage classic 95" se211 cam ported & polished 93 hp 100 tq
[IMG]local://upfiles/7791/9C631F6938B546C4BCEB9407494559C7.jpg[/IMG]
Old Nov 12, 2006 | 09:37 AM
DI75's Avatar
DI75
I am doing a 103 stroker build now with SE 258 cams. You DO NOT have to split the cases if you dont go above a 103!! Will take me about 3 weeks working evening only!! Will let you know how it turns out!!
Drumlord
EVO
11
Oct 24, 2018 08:10 AM
jpdeville
Engine Mechanical Topics
Aug 6, 2017 02:45 PM
DIRERIDE
Oct 1, 2013 09:26 AM
cmashark
Sep 20, 2009 09:56 AM
cardboard
Jan 18, 2007 01:18 AM
