Fatboy seat years
Old Jul 27, 2011 | 04:06 PM
irondude's Avatar
irondude
Default Fatboy seat years
Hello,
I need a seat for my 05 Fatboy, does anyone know what years are interchangeable? Thanks!
Old Jul 27, 2011 | 04:21 PM
jed1069's Avatar
jed1069
I believe it's 2000-06. Anything 07 and later has the 200 tire with wider fender.
Old Jul 27, 2011 | 04:25 PM
shineybike's Avatar
shineybike
I'm pretty sure 2000 thru 2005 are interchangeable. Possibly 2006 but I'm not sure on that one. The mounting technique change at some point around then. 2000 thru 2005 has the tab in the front and two screws on the sides, then the passenger seat is bolted to the driver seat and has a tab with an attached screw at the back end that screws into the rear fender. When they changed the seat on the newer bikes they got rid of the two side screws and added two mounting studs behind the driver seat that stick up thru the front of the rear fender. The passenger pad slides onto those studs and screws in to the rear of the fender. That makes it easier to remove the passenger pad without taking off the driver seat. I'm basing my answer on my 2004 heritage and the seats I've seen/owned. If I'm wrong about any of this, and that's always a possiblity, someone can chime in. Hope that helps.
Old Jul 27, 2011 | 04:38 PM
06 flstfise's Avatar
06 flstfise
Yep, you can go up to 2006, 07 was the 200 tire. I think you can go back before 2000 as well. Just test fit the seat. I have a le pera that is for a late 90's on my 06 fatboy.
Old Jul 27, 2011 | 05:07 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Drew
Old Jul 27, 2011 | 07:41 PM
Nickrc3's Avatar
Nickrc3
in front, one bolt in rear
Not my 04' FLSTF - stock seat had steel tongue in front, one single bolt in rear (into nutplate within fender). Doesn't the FLSTH have the side of frame mounting tabs?
Old Jul 27, 2011 | 08:33 PM
doubletap2910's Avatar
doubletap2910
I've got my seat off my 05' laying around, since replaced with a C&C... if interested PM me.
Old Jul 27, 2011 | 08:46 PM
ia2189's Avatar
ia2189
I've got an 06 stock seat with a Mean City Cycles mod if interested. I switched to a Mustang for the Mrs.
https://www.hdforums.com/forum/softa...ycles-mod.html
Old Jul 27, 2011 | 09:18 PM
KumaRide's Avatar
KumaRide
06 seat here, pm if interested... lol $50+ shipping.
Its in great shape!
Old Jul 28, 2011 | 03:56 PM
ia2189's Avatar
ia2189
I'm sure HDF has quite the inventory of stock seats given all the past threads on the subject ; )
Mike041
Apr 3, 2013 08:37 PM
fatboyslim25
Feb 10, 2012 09:57 AM
bikermama
Feb 27, 2010 10:57 AM
harleyheaven
Apr 14, 2009 08:01 PM
site351
Aug 6, 2007 07:55 AM
