Rough Idle 07 Heritage
Old Aug 26, 2011 | 05:51 PM
BigDog07's Avatar
BigDog07
4th Gear
Default Rough Idle 07 Heritage
Well I'm a new member and i have an 07 Heritage. I have searched the forums much, and learned a few things I didn't know but my eyes are buggin from the pc screen, so I'm just going to post.
I have had 2 '80 model rice burners that I did all my own work on, and have had the Heritage for 3 years now. I got the extended service plan and have been on time with all service intervals, and after the plan was up, paid for the 30k checkup. It has never given me any problems, has always been good to me.
The other day I went out for a ride and stopped to fill up, as soon as I left the gas station it started spitting and sputtering and hesitating. I got it home and figured bad fuel, so I drained the tank,(siphoned the old fashion way) got fresh fuel and added some Sea Foam. (1 oz per gallon) My wife wasn't happy about me using the measuring cup out of the kitchen, but she will get over it. When I went to start the bike, found the battery dead. Trickle charged it, got the bike started, but it idles fine for about a minute then hesitates with an air puff sound in between hesitations. I'm thinking next might be the fuel filter, or maybe a hole in the fuel line sucking air, or electrical... Any ideas?
Thanks
BigDog
Old Aug 26, 2011 | 06:28 PM
oc1014's Avatar
oc1014
Bad battery.
Old Aug 26, 2011 | 06:29 PM
Other Sheep's Avatar
Other Sheep
Sounds like possibly the filter or hole in the hose. Or.
I was coming home from Yosemite to SoCal a couple summers ago and stopped in Bakersfield, hot hot Bakersfield. Filled the bike, went inside to get a water, got back on the bike and a few feet out of the station the bike stuttered and acted like it wanted to die. What happened was I filled it to much, the heat expanded the fuel and put too much pressure on the system. Ran it a mile or two and all was fine.
It's hot in Texas right now isn't it?
Old Aug 26, 2011 | 08:52 PM
pnw_hd_rider's Avatar
pnw_hd_rider
Since the battery was dead it's probably a problem with the charging system or the battery. EFI doesn't work properly on low voltage do that's probably why it was running like crap.
Old Aug 26, 2011 | 10:29 PM
oct1949's Avatar
oct1949
The hole in the gas line is now common on bike 4-5 yr old,, I just had my replaced last month... But it dosen't uaually start till 80-100 miles after a fill up.
Mine had 33k on her with it started..
Supposed to installl new filler at 25k, but i went longer.
The wrench say's the Ethanol gas is causing the problem and now after reading most new boat's are having the same Issue's.
so,,,,, change out everything inside the tank to see is its the issue.. Its time anyway...
Old Aug 27, 2011 | 09:46 AM
BigDog07's Avatar
BigDog07
4th Gear
Default re:
Thanks for the fast feedback.
It is very hot in Texas right now, too hot to ride some days. I'll try the suggestions. Thanks for all who replied.
BigDog
Old Aug 27, 2011 | 11:54 AM
oct1949's Avatar
oct1949
Another possibility is one or both of the bolt to the battery loose.
I had a intermittent miss couple yrs ago, both of my bolts were not tight.
Old Aug 27, 2011 | 09:53 PM
BigDog07's Avatar
BigDog07
4th Gear
Default re:
I have had the battery go bad and got stuck out away from home and had to jump start it. It didn't run any different on the way home with a jump start. So I have ruled that out. My thinking is the hole in the hose and or the fuel filter. It does crank up and run, but acts like the fuel pressure is intermediately interrupted continually. In my Harley engine uneducated some what have worked on other bikes before opinion I'm thinking the fuel pump is good, but the filter isn't allowing continuous flow.. Airgo the filter or sucking air from a hole somewhere..or both.
Mason.t1994
General Topics/Tech Tips
Sep 21, 2017 03:04 AM
hdgeno777
Aug 31, 2015 12:11 AM
brenth
Dec 24, 2012 12:44 PM
Georgepty
Apr 4, 2012 09:44 AM
derose
Oct 18, 2009 02:24 AM
