Brake upgrade advice needed
Old Sep 20, 2011 | 05:33 PM
ejvette's Avatar
ejvette
Originally Posted by Malingerer
I just put the same set up on my scoot about a month ago.PM 4 piston rear,6 piston front in chrome.Just used the PM pads that came with the calipers.Stock master cylinder with Magnum sterling chromite cables and Ride wright polished rotors.I feel the braking was a noticeable difference with the PM calipers.I would not say dramatic or huge though.It is a dramatic difference in looks and bling factor.As usual Dr V Twin hooked me up with a sweet a$$ price as well.
Did you do the work yourself how hard was it doing the rear?
Old Sep 21, 2011 | 07:52 AM
Malingerer's Avatar
Malingerer
This time i did not.But I have had the rear wheel and caliper off plenty of times.You will have no problems with this at all.It is a direct bolt on.The only difference is the stock caliper and bracket are two separate pieces.The PM caliper is a one piece unit.The front is just a matter of taking off 2 bolts and disconnecting the brake line.Bleed brakes and done
Old Sep 21, 2011 | 08:02 AM
Miked053's Avatar
Miked053
hey drew, am I missing something or does PM not make this kit that will fit the Lo yet and maybe black instead of chrome?
Old Sep 21, 2011 | 08:38 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
They make black contrast cut calipers that will fit your bike.
Drew
rauchman
Jun 25, 2023 05:47 AM
Evoken
May 8, 2017 09:32 AM
LA_Dog
Jul 5, 2016 12:16 PM
AjAnd3rson
Nov 21, 2011 05:32 PM
Rebyl
Jan 1, 2011 09:03 PM
