06 softail (fuel injected) mis-fires
Old Oct 16, 2011 | 11:52 AM
1cabinman's Avatar
1cabinman
Stage IV
Default 06 softail (fuel injected) mis-fires
Sometime After removing the "hines" exhaust and installing the factory pipes my (new to me) bike starting mis-firing (also used reg. octane fuel - but two tanks of 93 octane since). This happens after a brief warm up, in first gear and seems to stop mis-firing after a few miles. Also, it has stalled a few times - which is dangerous!
This is what I have done:
1. Sea Foam in 2nd and 3rd tank. (93 octane)
2. checked for error codes, No errors.
3. Remove battery connection (to reset computer?)
4. Checked air filter - may need a new but not that bad.
5. Was told by org. owner that he had done nothing to change timing/firmware etc. for hines exhaust. (Bike has 11,000 miles.)
The bike seems to idle a little low, just after start up.
Any suggestions?
Old Oct 16, 2011 | 12:50 PM
hamdizle's Avatar
hamdizle
I'd check you're ecm...It might need recalibration....have the map reloaded...
Old Oct 16, 2011 | 04:42 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Did you use new exhaust gaskets when you put the stock exhasut back on? Check for intake leaks and exhasut leaks at the heads.
Drew
Old Oct 16, 2011 | 05:18 PM
1cabinman's Avatar
1cabinman
Stage IV
I replaced one, because the dealer had only one. I think your are referring to the "rings" that allow the collar to pull up to the head, thus creating a seal?
Old Oct 16, 2011 | 10:29 PM
KumaRide's Avatar
KumaRide
06's had injector service bulletin. If yours are 8 degree injectors they should be replaced with 25. The symptoms are exactly what you describe - runs rough cold, rough idle when cold. I have no idea why it appeared after 11k miles and/or exhaust swap. You can check your injectors per the file below. The dealer swapped mine for free.
http://www.box.net/shared/gm9evapytd
Old Oct 17, 2011 | 05:56 PM
1cabinman's Avatar
1cabinman
Stage IV
KumaRide, Thanks for the advise! This could be the issue, the org. owner swap parts from Softail to softail (+5 or so bikes!) and told me "he" never had the factory pipes on... I assume the local dealer (a different one from the org. owner) could tell me if the injector was replaced using the VIN? . I don't think I can see the injector without removal of other parts?
BTW, is that your Cobalt/silver FatBoy? My Softail is the same colors. Nice looking bike you got if that is yours.
Old Oct 17, 2011 | 06:56 PM
KumaRide's Avatar
KumaRide
Call a dealer and ask if they will check them out and reference the service bulletin number. If they say no, call the Moco directly and see what they say. That is who I went through first.
Yep, cobalt blue and silver. Shiet, that makes two of us on this site...
Old Oct 17, 2011 | 07:10 PM
1cabinman's Avatar
1cabinman
Stage IV
I found the injector after looking on both sides and then back to the correct side (Double yellow side!) Looking like I will be visiting the shop again.
Afterwards, well see how she's runs!
Old Oct 17, 2011 | 08:14 PM
KumaRide's Avatar
KumaRide
Does your bike have a stage 1 download? Not sure what you have. If it does have stage 1 then you should get a new one made for the 25 injectors. The dealer uploaded a new version when they swapped out my 8 for 25's. Good luck!
j8kenb8ke
Exhaust System Topics
22
Oct 16, 2018 01:40 PM
Dante Castro
Jul 29, 2017 12:47 PM
micheal-s
Jun 23, 2011 05:20 PM
blueduramax
Jul 16, 2010 06:23 PM
charlie1
Nov 29, 2004 02:19 AM
