Tail light wiring question
Old Feb 6, 2012 | 09:54 AM
dboutfitters's Avatar
dboutfitters
6th Gear
Is there a nut on the inside of the fender or does the strut bolt thread into a flat boss inside the fender like on the heritage? Either way, maybe you can try this:
I had the same problem before and ran a quick sinch knot with some high test strength fishing line through a flat washer, leaving plenty of length to tie the wires up in. After the strut bolt was tightened back up I tied the wires off with the excess line. As long as the fishing line is just compressed in the washer it will hold every bit as good as a zip tie, and this solution was ultra low profile and will be plenty secure.
Old Feb 6, 2012 | 12:08 PM
JakesDad1's Avatar
JakesDad1
Through trial and error (a lot of trial and error), I found that a tight fender is not condusive to under fender wiring.
I gave up trying and went with external wiring zip tied to the swingarm. Good luck.
Old Feb 6, 2012 | 06:09 PM
RANGER73's Avatar
RANGER73
How about cutting the flat side off, and reducing the arch on the strap.Then use zip ties to hold the wires secure to he strap. I don't recommend the 1x1 zip tie holder, or double sided tape, not under the fender.
Old Feb 6, 2012 | 06:53 PM
jharanin's Avatar
jharanin
Nice! I knew you guys would come thru for me....
Old Feb 6, 2012 | 06:56 PM
jharanin's Avatar
jharanin
Ranger...you are the man! Might not do exactly that but it gave me another idea using your idea in general. I'll let u know how it works out
A huge thanks to all of you for the ideas....I hope some day I can help you all out....ride on
Old Feb 6, 2012 | 06:58 PM
jharanin's Avatar
jharanin
That is freakin tight....looks killer though.
Nooovie
Aug 15, 2012 08:23 AM
duke5
Aug 19, 2011 02:07 PM
Gary86
Jul 3, 2011 11:04 PM
Naz_Man
Jan 24, 2009 08:37 AM
KBES BAGGER
Mar 12, 2006 09:41 PM
