Additives...do they work?
Old Sep 3, 2012 | 05:12 PM
Rick341's Avatar
Rick341
Default Additives...do they work?
Do fuel additives like injector cleaners work without causing any damages?
I believe additives such as Sta Bil and injector cleaners work against the harmful effects of ethanol on marine outboard motors ...just wondering if they'd work the same way in the Harley???
Old Sep 3, 2012 | 05:39 PM
PureDeath's Avatar
PureDeath
Ive used both, and have had no problems at all. I tend to use injector cleaner once in a while, but I use StaBil fuel stabilizer in the weather and while riding down by the gulf.
Old Sep 3, 2012 | 05:42 PM
Wide_Open's Avatar
Wide_Open
I use the Stabil marine for ethanol in my bike, add a little after every fill up. I'm hoping it's doing it's job. Time will tell.
Old Sep 3, 2012 | 08:20 PM
teflon's Avatar
teflon
Stabil works for storage uses and injector cleaner works to clean injectors. But be advised most additives DO NOT mix with gas!!! We did some pretty extensive testing when we race stockcars and the lab results showed that they don't actually mix with the fuel. Stuff such as octane boost ....is a total waste. Teflon
Old Sep 3, 2012 | 11:14 PM
Rodzilla6's Avatar
Rodzilla6
I have been putting about a capful of Lucas oil upper cylinder lubricant/fuel system cleaner in a full tank much of the time but not always. The marketing stuff on the bottle sounds good, not sure I notice any diff. in how it runs. I was trying to get a little lube in the cylinder on the way up to cut down on wear and keep the injectors clean.
Old Sep 4, 2012 | 06:28 PM
oct1949's Avatar
oct1949
I use Marvel Mystery oil about 2-3 time a Yr, and sta-Bil during storage...
Old Sep 4, 2012 | 06:56 PM
TheTroupe's Avatar
TheTroupe
Marvel Mystery Oil, now that's a name I haven't heard in a long time.
Have you tried STP?
Old Sep 4, 2012 | 07:01 PM
olongapo1's Avatar
olongapo1
Seafoam. Great stuff!
Old Sep 4, 2012 | 07:11 PM
Jesla's Avatar
Jesla
grandpatim
Oct 23, 2019 11:09 AM
craig11dyna
Sep 30, 2013 08:08 AM
yso191
Exhaust System Topics
16
Jun 3, 2013 08:46 AM
TWIN CAM 96
May 15, 2011 05:27 PM
FloridaDrafter
Apr 29, 2008 06:57 PM
