Spark Plugs & Wires
Old Jul 6, 2013 | 07:08 AM
Reaper 9's Avatar
Reaper 9
Default Spark Plugs & Wires
At what miles or time have you guys changed your plugs and wires? I'm coming up on my 10,000 mile service and I'll be doing it all!!
Thanks
Old Jul 6, 2013 | 08:35 AM
Bone Doc's Avatar
Bone Doc
According to my factory service maintenance schedule, the plugs on my 2012 Heritage should be changed at 30,000 miles or two years, whichever comes first. I will check the plugs at each service interval though. If they appear to require changing, I will; otherwise I follow the maintenance schedule.
I changed my wires to braided plug wires within days of delivery. There are several places to get spark plug wires. One is below.
Braided Spark Plug Wires
Old Jul 6, 2013 | 08:47 AM
QC's Avatar
QC
I've been changing my plugs at beginning of each riding season just cuz that is how i am. I also put on the SE plug wires last year.
Old Jul 6, 2013 | 08:57 AM
Reaper 9's Avatar
Reaper 9
I check my plugs and there burning just fine !! When the time comes what kind of plugs and what heat rang is everyone running? I know the heat rang will very from state to state and motor but I can't seem to find out what the heat rang is that comes stock on my 09 Fat Boy! It's a bit warmer down here in FL in the summer than lets say NY. My stock plugs seem to be doing well so far. But then again I had mine tuned for here in stead of running lean from the factory.
Thanks for the help Bone Doc.
I like the looks of those wires!!
Old Jul 6, 2013 | 10:01 AM
Reaper 9's Avatar
Reaper 9
IM running NKG Plugs DCPR7Es and when I checked the gap was way off ( closed to much) maint. books said 38-42 and they were around 35?? Fixed now and looking at some new wires!!
Thanks
Old Jul 8, 2013 | 05:58 AM
oct1949's Avatar
oct1949
I am at 42K and on the 2nd set of plugs and still have the Org wires on her.
I do have a new set of plugs (Same as Stocker) and new SE wires, but there sitting in the Garage Cabs till I take time to install the.
I don't usually don't fix what ain't Broke.
Old Jul 8, 2013 | 06:12 AM
Iceman24's Avatar
Iceman24
If there's no reason to swap, other than pretty colors and spending unnecessary $$$, run 'em to 25-30K.
Old Jul 8, 2013 | 07:13 AM
Warp Factor's Avatar
Warp Factor
Personally, I'll be keeping all ignition components stock to keep the ion-sensing detonation control system working properly. That's a really neat setup, and I'd hate to unintentionally disable it, or render it less effective.
Old Jul 8, 2013 | 12:58 PM
vizcarmb's Avatar
vizcarmb
No need to change plug wires unless the insulation is pretty cracked up and worn down from the weather.
Ndoggct
Sep 21, 2016 07:02 PM
Kahuna
Jun 5, 2015 07:30 PM
oldairboater
Jun 24, 2011 09:43 PM
zaxcar
EVO
Oct 18, 2009 03:44 PM
paintballoma
Jun 6, 2007 11:18 AM
