Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Apr 25, 2015 | 02:04 AM
  #2541
wickedweasel13's Avatar
wickedweasel13
6th Gear
Smile
Originally Posted by burnsy87
... okay here's a dumb question.
Asked earlier about adding a Breakout to my Sportster for something different, but I didn't realize quite how stretched out the rider is. I'm only 5'6 (yeah.) and was wondering if the reduced reach seat and some different bars would make it comfortable for me?
I'm 5'6 and I went with the HD reduced reach seat and swapped over to the FatBob style drag bars (my buddy changed to apes which allowed me to score them free) this helped me fit very comfortable on my BO
Old Apr 25, 2015 | 02:28 AM
  #2542
LA_Dog's Avatar
LA_Dog
Originally Posted by Dynaunder
Hi La_dog , I could not upload pic on PM message . but here it is and thank you again
Dynaunder
Thanks Dynaunder- nice "stable" of scoots you got there.
Yeh I think your suggestion of getting on the Sportster 1200 rear 68T pulley, and replacing the Breakout 66T pulley is a fantastic idea. I see that in your photo and indeed it's a direct bolt on. Uses the same belt, better low end gear ratio, inexpensive part, what's not to like??
PN 40354-07 for 2007 and up XL 1200, and of course a new set of bolts (cannot re-use old bolts they are specifically torqued one time and that's it.) I think the bolts are 7 1/6 x 5 x 2" - or maybe it's PN 40518-07 - I gotta research this.
Saves me a lot of time with swapping the front pulley. I was not at all looking forward to pulling the primary.
Old Apr 25, 2015 | 02:52 AM
  #2543
LA_Dog's Avatar
LA_Dog
Alright so here's the scoop on the Sportster 1200 68T pulley and bolts:
2011 XL1200 pulley PN 40444-07 (black, like the 1st photo in Dynaunder's post) or PN 40350-07 which is chrome Retail $197
Sportster bolts are 7/16 - 14 x 1-3/4" PN 3899 hex bolt with lock patch $1 each
Breakout bolts are 7/16 - 14 x 2-5/8" PN 3109 hex cap bolt with washer / lock patch $2 each
I think the center 5 bolt hole areas on the sportster pulley are thinner than the Breakout, hence the shorter length bolts.
Old Apr 25, 2015 | 03:10 AM
  #2544
Dynaunder's Avatar
Dynaunder
Hi again LA_Dog , I think if anyone does a job right it is you , just putting it out there, I have a high flow intake like the one you have on your bike , I allways wanted to re-route the head breathing hole to the outside to bypass the intake manifold.
I was thinking to drill and tap copper fitting to the crome cups and a internal connetting rubber tube on the high flow breather some braided lines and for enviromental reason have a canister to catch the oil and condensation overflow.
Love to ear your comments and apologies about my etnic spelling and grammer
Dynaunder
Old Apr 25, 2015 | 03:24 AM
  #2545
LA_Dog's Avatar
LA_Dog
Thanks- I'll either do it right or screw it up, one or the other. hah
The breather mod sounds ok- sort of like my Evo bike. If you do something with it definitely post some pics.
Old Apr 25, 2015 | 03:27 AM
  #2546
LA_Dog's Avatar
LA_Dog
I found some real info from another forum (who shall remain unnamed), here is the main part:
Installed 68T Sportster belt pulley on late model Softail
« on: Sunday, March 15, 2015. 05:10:55 AM. »
Thought I would post this up since there has not been much discussion about this mod for Softails. This is the easiest and cheapest way to lower the gearing to what the touring bikes have on late model Softails. My bike is a Softail Slim so my experience may not be the same for other models. All 07 and up Sportsters have a 68T pulley. The difference in part numbers is for the color and style. The stock pulley has a 1/4 inch thicker mounting flange but the Sportster mounting flange is offset 1/4 inch further in so the overall fitment was a wash. So I did not need a spacer. Different models and bikes with cast wheels might so measure to make sure. My upper and lower belt guards fit fine and the belt was easy to get on. What you will need is 5 7/16 x 14 x 2 inch grade 8 bolts and washers. The stock bolts will be too long and the washers dont come off the stock bolts. You also need a 12 point 1/4 inch socket and a 40 torx socket to remove the brake caliper and pads. Hope this is some help to anyone considering this mod.
And here is a pic of the pulley- this is PN 40350-07 for 07 sporty's
Old Apr 25, 2015 | 04:01 AM
  #2547
NSR's Avatar
NSR
...OK, so which one of us chuckleheads is gonna go first.....?
Old Apr 25, 2015 | 06:11 AM
  #2548
burnsy87's Avatar
burnsy87
Okay thanks man
Old Apr 25, 2015 | 08:56 AM
  #2549
LA_Dog's Avatar
LA_Dog
well prolly me- shopping around right now. best price I found so far is $157 new. might as well give it a try since I was planning to pull my rear wheel anyway to put in the factory security system BCM
Old Apr 25, 2015 | 08:59 AM
  #2550
LA_Dog's Avatar
LA_Dog
2T up on the rear is not quite as good as 1 or 2T down on the front, but definitely a step in the right direction- and the bonus would be keeping the same belt.
