Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Feb 24, 2017 | 01:32 PM
  #5421
NSR's Avatar
NSR
Originally Posted by wedgemoose
WOW... that's the same exact thing that happened to me!!! My turn **** fell off. And i put right back on and tightened the set screw. Ever since that the key won't turn in the cylinder. I even loosened it to see if the screw was putting too much pressure on it or something. But no luck. Weird the same happened to both of us.
But i did not know the dealer could do what you say? the parts book says you need to buy the set(ignition and fork barrel/key sets). So that's great news. I would much rather only change out my ignition side but thought you could only do both or none. Nice!!! thanks.
Yep, I went into the dealership ready to fork over the cash for the set. The parts dude straightened me out. Worked out good.
How did you get the switch out of its mount? You need a special spanner socket for that...I did anyhow....
Old Feb 24, 2017 | 01:53 PM
  #5422
wedgemoose's Avatar
wedgemoose
Again good man!! I would of never done that. Would of bought the set. My dealer does suck though. They never help me out. But now that I know i'll straighten them out if they try and blow me off.
I used the old spread open needle nose pliers trick. Actually worked like a dream(once I broke free from the blue loctite). I always have to do that trick with my 4WD hubs and stuff. Usually works but sometime it doesn't.
didn't damage the nut holes or anything. Can't even tell i screwed it off.
Old Feb 25, 2017 | 05:13 PM
  #5423
Matos's Avatar
Matos
Default Swingarm bag
Hey guys, just wondering if anyone here knows who makes the swingarm bag that they put on the special edition slim.
Old Feb 26, 2017 | 03:25 AM
  #5424
HKMark23's Avatar
HKMark23
Just mulling over the idea of adopting 27 1/2 or even 29 1/2 front fork tubes. I'm just wondering how much the increased trail will adversely affect the already somewhat planar BO handling.
Also, what to do about jiffy stand ?
Thanx All.
Old Feb 26, 2017 | 08:55 AM
  #5425
JimGnitecki's Avatar
JimGnitecki
Thanx All.
One way of alleviating the "planar handling" of the Breakout notably is to change to more responsive tires. If you have not yet done that, try it. Worked exceedingly well for me with a Pirelli Diablo pn 1682600 on the rear, and an Avon Front AM41 Venom X 120/70H-21 68H Blackwall Tire - 90000000753 or an Avon Front Cobra AV71 120/70V-21 Blackwall Tire - 90000000746.
Jim G
Old Feb 26, 2017 | 09:27 AM
  #5426
HKMark23's Avatar
HKMark23
Jim G
Thanx Jim, much appreciated.
I was considering the forks for more of a cosmetic change than anything else really. I'm certainly not a performance type rider but didn't want to turn my BO into a flat car in the corners for the sake of image either. My current E3's are new (rear to be installed in spring). I'm gonna give those Pirelli's a try at next change though. You and LA and 24V endorsing em makes them an easy choice.
Old Feb 26, 2017 | 03:36 PM
  #5427
tphykitt's Avatar
tphykitt
Thanx All.
If you have instagram look up akairaider. He did 5 up over stock on his fork tubes. I hear if you do 2 up it won't affect the handling that much according to my mechanic. Anything above puts you in 'mystery trail' territory.
Old Feb 27, 2017 | 05:25 AM
  #5428
K9F's Avatar
K9F
Stab in the dark here! La Rosa perhaps?
http://larosadesign.us/harley-leathe...s-and-luggage/
Old Mar 4, 2017 | 11:23 PM
  #5429
Freak Show's Avatar
Freak Show
can someone tell me the height of the risers on a break out and how many inches of pull back they are.
Old Mar 5, 2017 | 05:00 PM
  #5430
02603SEC's Avatar
02603SEC
I measure 3-1/2" from the top tree to the bottom of the bars. Aprox. 1" of pull back.
