Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jun 4, 2017 | 06:56 PM
  #5681
matte's Avatar
matte
Originally Posted by Curt Ehrhart
Top plate is easy. 10 screws and just need to pop off the fuel pump.
but, you should buy 10 new self sealing screws and might as well replace the gasket while you have it off.
make sure you don't over torque those screws.
Did you empty the track before swapping?. Stupid question, but I've never disassembled my tank before.
Old Jun 4, 2017 | 07:01 PM
  #5682
NSR's Avatar
NSR
No, you don't need to empty the fuel tank. IIRC, I ran mine down to about 1/2 before switching over to the Blackline parts. It was easy.
Old Jun 4, 2017 | 09:07 PM
  #5683
Odinbreakout9's Avatar
Odinbreakout9
How hard was the top plate to swap?
Just as Curt has stated. Replace the screws (I did as well). The top plate will come with a new gasket already attached. The only major difference in installing the CVO dash instead of the Blackline dash is going to be the dummy vent line that runs under the tank. There is another person on here who said he managed to do it without removing the tank.
Old Jun 5, 2017 | 06:53 AM
  #5684
matte's Avatar
matte
Are the screws HD sells on the parts break-down the self-sealing type? I didn't order them, but will now that I see that as a suggestion.
Old Jun 5, 2017 | 11:44 AM
  #5685
Curt Ehrhart's Avatar
Curt Ehrhart
The part number is 1311d. Just in case you need to compare
Old Jun 5, 2017 | 12:14 PM
  #5686
matte's Avatar
matte
Done! thanks for the tip!
Old Jun 13, 2017 | 09:53 PM
  #5687
Curt Ehrhart
4" risers and a tank bib. Still need to hook up the dash lights.
Old Jun 13, 2017 | 10:12 PM
  #5688
matte's Avatar
matte
Officially cut a remodeled backrest for my breakout. The pad is aftermarket, but the backrest frame is my own design. Works well to keep the butt in place on the stock seat. Just needs some powder coat.
Old Jun 17, 2017 | 04:33 PM
  #5689
cdonis's Avatar
cdonis
Just pulled the trigger on the 124 hot set up kit from S&S. Also a s&s tc3 cam oil pump / support plate. 58 mm tb, and an oil cooler, and a primo Rivera pro clutch. Should make a nice package for the breakout!
Old Jun 21, 2017 | 05:19 PM
  #5690
JerzeyDevil's Avatar
JerzeyDevil
For you guys running fork gaiters, are there any tricks to help keep them up? I have one side that stays where it's supposed to but for some reason the top of the other one keeps sliding down.
