Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Nov 11, 2017 | 10:20 AM
  #6081
cdonis's Avatar
cdonis
Originally Posted by Jessica Sinclair
How do i check and fill the engine oil? What kind of oil is best for stage 5 110ci Harley Breakout?
Could someone please make video or post picture of where to check oil please
check the oil here, with the bike warmed up on the kickstand. Use any 20/50 synthetic vtwin oil you want. Btw, you add /fill oil here too.
Old Nov 11, 2017 | 10:34 AM
  #6082
Jessica Sinclair's Avatar
Jessica Sinclair
Thank you so very much xoxoxoxo
Old Nov 11, 2017 | 10:54 AM
  #6083
JimGnitecki's Avatar
JimGnitecki
Jessica: Check the user manual. There are some important details, like:
- Do it when the engine is at normal operating temperature, not when it has just been started, and certainly not when it has been sitting "off" for more than a few minutes (oil tends to drain back into the engine sump for an inaccurate reading)
- Wait 2 to 3 minutes after shutting the engine off. Do not do it sooner, nor significantly later than that
- Do NOT overfill!
- Clean the dipstick FIRST and then screw it back in to take the actual reading
If you want to make it MUCH easier, buy the HD accessory "digital" dipstick. With that, you simply wait the 2 or 3 minutes after shutting the engine off (e.g. after pumping gas), press a button, and it shows you both oil level and oil temperature without having to remove and replace the dipstick twice. Mine has worked reliably for about 4 years so far . . .
Jim G
p.s. Yeah, I did notice the "Stage 5 100 cu in"
Old Nov 11, 2017 | 12:29 PM
  #6084
splattttttt's Avatar
splattttttt
$150 for a dipstick?
Old Nov 11, 2017 | 12:31 PM
  #6085
Jessica Sinclair
- Do NOT overfill!
Jim G
Thank you
Old Nov 11, 2017 | 02:22 PM
  #6086
JimGnitecki
AND a digital TEMPERATURE gage. I got it for the tmperature gage primarily, with the automatic dipstick reading being a convenience plus.
Watching the temperature gage when I was still in Texas was VERY educational, both in terms of how hot the oil got on hot summer Texas days, and also for how long it took to get up to temperature, both normally and on really cold winter days.
That gage is why I got my oil cooler, which made a HUGE difference. After installing the oil cooler, the temperature rarrely got above 215 and usually ran around 190 to 200. Now, in the "Mediterranean" Vancouver Island climate, I rarely see 200.
And, the bike uses no oil between oil changes.
Jim G
Old Nov 11, 2017 | 08:05 PM
  #6087
NSR's Avatar
NSR
...If you want to make it MUCH easier, buy the HD accessory "digital" dipstick. With that, you simply wait the 2 or 3 minutes after shutting the engine off (e.g. after pumping gas), press a button, and it shows you both oil level and oil temperature without having to remove and replace the dipstick twice. Mine has worked reliably for about 4 years so far . . .
Jim G
The one I bought didn't last quite that long... it died this past summer. So that's about 3 years/15,000 miles. I opted to NOT get another one. I've been searching around for a screw-in cap with an analog temp gauge - no dice.
Old Nov 12, 2017 | 07:24 AM
  #6088
splattttttt
My wife’s x- ones has the analog type. Nice to know her motor has be er gone abobe 220 in stop and go. Usualy in the 180-195
My Slim, ot so good. Usually end up having to add 1.5qt between the 5k mi change
Goin for the oil filter relo D&K has which should also help with cooling. But no cooler yet LOL
Old Nov 12, 2017 | 08:27 AM
  #6089
HKMark23's Avatar
HKMark23
Write down some record of temps just before you do the relocation so you'll have a firm basis for comparing results of the relocation. You will see a drop in temp. You'll enjoy easier, less messy oil changes too along with eye catching, IMHO, aesthetics.
If your relocation kit doesn't break the bank, you might want to investigate the benefits of switching to a permanent filter too. With the filter "out there", the aesthetic appeal of the filter itself becomes somewhat more important as well. "Permanents" also have benefits which go well beyond appearances too.
Old Nov 12, 2017 | 08:31 AM
  #6090
splattttttt
Thanks man. Both bikes have the re usable filters already in place (;
