Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Apr 28, 2019 | 09:51 AM
  #6831
EagleRay's Avatar
EagleRay
Originally Posted by showin4fun
I don't know if it just me but the video you took of the SE-204 Cams does not sound much different that my stock cams at idle. Do you think there is extra lope at idle?
Those 204s sure sound different from the stock ones especially if you lower idle rpms to the save min at about 950. But after all it's the gain in performance you get with them. But to optimize you should get it dynoed properly.
Old Apr 28, 2019 | 10:28 AM
  #6832
Blackp5ca's Avatar
Blackp5ca
Glad winter is over...it was an expensive few months.
Old Apr 28, 2019 | 10:38 AM
  #6833
Superdog3:16's Avatar
Superdog3:16
Maaan, I like it! I wanna do a tailjob like that bad, but, the tail kit
Paint
Seat
Air shock to make it look,then ride right
EXPENSIVE! LOL
Old Apr 28, 2019 | 06:49 PM
  #6834
vtchopperdude's Avatar
vtchopperdude
I bet!!! That rig looks gooooooooooooooood!!!!!
Old May 4, 2019 | 08:36 PM
  #6835
vtchopperdude
Well damn, my ignition thumb lever fell off somewhere while I was down at Thunder Beach today. I stopped by the dealer and they only sell the whole ignition assembly, even though the thumb **** has it's own part number (71796-11). Has anybody found an aftermarket replacement?? $209 for the whole assembly plus a rekey is highway theft...
Old May 5, 2019 | 01:57 AM
  #6836
MoneyFor's Avatar
MoneyFor
They can be bought seperate, I while back was one on Ebay new in HD wrapping for Ł15 or $19,76. You can make one yourself, on a German forum a member lost his and made one on his lathe.
Not so good looking as the oem but functional.
Your part n° is correct
Old May 5, 2019 | 04:22 AM
  #6837
NSR's Avatar
NSR
That's a good idea - just a knurled ring with a set screw.
I wonder if you could machine it so closely that you'd have to heat the ring in order to get it onto the switch. Then when it cooled off it'd be on so tight that it would never come off. The set screw could be eliminated.
Old May 5, 2019 | 04:42 AM
  #6838
MoneyFor's Avatar
MoneyFor
That could be possible, I work in metric system and if I want to shrink something I give it a few 100ste of a mm tension, then heat it so it expand and put it over
the part where it needs to be shrinked on. The only disadvantage of heating is the coloring of the metal, I would have used RVS for this and after heating so it
expands it will be colored brown blueish.
Old May 5, 2019 | 06:43 AM
  #6839
vtchopperdude
Has anybody seen the 3D printed *****?
https://www.ebay.com/itm/3D-Printed-...h/202668396336
It't not the original shape as the factory ****, but looks like it may work. There isn't a "thumb" **** on it, but I guess you can still grip it to turn the ignition. Thoughts?
Old May 5, 2019 | 06:46 AM
  #6840
showin4fun's Avatar
showin4fun
Just finished one up yesterday. Made a couple extra at the same time, I did mine with a small peg on top so it could be turned easily and then powder coated
it satin black. Also did the flat on the bottom to match the HD switch so there would not be any gap. Also finished up my oil temperature gauge. Machined out the
OEM Breakout oil dipstick and inlayed a temperature gauge with a long enough stem so that it can be used as a dipstick too.
