Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Oct 15, 2020 | 07:07 AM
  #7351
vtchopperdude's Avatar
vtchopperdude
Does the triple tree neck nut take a 1.5 inch socket? The service manual shows the schematic and talks about torque values, but not the actual size needed. Just crusing youtube, I think that's what it calls for, but just wanted to be sure before buying a 1.5 inch socket.
Old Oct 15, 2020 | 07:35 AM
  #7352
MoneyFor's Avatar
MoneyFor
Yes you need a 1-1/2" socket for that one.
Old Oct 16, 2020 | 12:23 AM
  #7353
vtchopperdude
Thanks brother!
Old Oct 29, 2020 | 08:59 PM
  #7354
TCZ's Avatar
TCZ
Greetings,
I posted this question in the lighting forum, but thought I would try here too. I noticed lots of Breakout guys get rid of the big bullet turn signals on the handle bars and replace with something smaller. I like these ones from Drag Specialties, but they have to be wired up with a circuit kit to make them dual function as turn signals. Is anyone running something similar that is dual-function right out of the box?
https://chromeglow.com/products/hand...custom?id=8254
Appreciated.
Old Oct 30, 2020 | 04:38 AM
  #7355
showin4fun's Avatar
showin4fun
Originally Posted by TCZ
Greetings,
Appreciated.
I run those turn signal lights on my Breakout. I am just using the single turn function.
Old Oct 31, 2020 | 04:50 PM
  #7356
vtchopperdude
I run the same turn signals! And I have them wired up the same way as showin4fun!! They are very covert, so having the dual function kinda defeats the purpose of them IMHO. Wired up as running lights, you'll see them ALL the time, as opposed to wired up single function and they only illuminate when the turn signals are activated. Just my 2 cents, but they are WAY better than the stock signals!
Old Oct 31, 2020 | 04:55 PM
  #7357
TCZ's Avatar
TCZ
Thanks guys. Any voltage related issues or just plug n play?
Old Oct 31, 2020 | 05:51 PM
  #7358
K9F's Avatar
K9F
If you have CanBus you may need a load equalizer? I bought very similar ones from Thunderbike and to keep your instrument cluster indicator flashing at the correct speed an equalizer was needed. A single equalizer is needed for all four indicators on a non CanBus bike or two equalizers for a CanBus bike one for each pair of indicators front and rear respectively.
https://shop.thunderbike.de/en/Thund...equalizer.html
Old Nov 8, 2020 | 10:41 AM
  #7359
TCZ's Avatar
TCZ
I ended up ordering the Drag Specialties front signals and will wire them as signals only as you guys suggested. Thanks for the the info and advice!
I also ordered these rear LEDs from Wunderkind Custom in Germany. They are Euro spec (have 4 wires per side) but my mechanic says he can wire them up to work, no problem. His shop specializes in stereos for Harleys so I am confident I think they are pretty cool lights and unique.
https://wunderkind-custom.com/en/mot...s-for-fender-?
*Also just received my Legend Air shock so will be getting it installed soon as well. Things are coming together!
Cheers
Old Nov 8, 2020 | 02:16 PM
  #7360
vtchopperdude
Legend is...welll....Legendary!!! Love my Legend Air Ride kit!!!
