Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jan 25, 2022 | 03:49 AM
  #7521
Phage's Avatar
Phage
6th Gear
Default Foot peg risers
So I've been a fan of the breakout for awhile but I noticed that there isn't much ground clearance so I was wondering if there's anything that can put the foot pegs higher up (the FXDR's foot pegs look like they have some sort of riser).
Old Feb 6, 2022 | 05:13 PM
  #7522
SXR's Avatar
SXR
Stage III
Default FXSB Tires
Originally Posted by Red Rage
Hi
I have a 2017 Breakout with original tyres on it. They need replacing. Anyone have a suggestion for the best tyre options for my bike?
Hi,
I'm riding same bike Breakout FXSB 2017. Using Michelin, either Commander 2 or SCORCHER 11. On both, I can tell you that Rear Tire will hold ~20,000km, and front ~40,000km.
Old Feb 6, 2022 | 05:52 PM
  #7523
SXR's Avatar
SXR
Stage III
Hi,
From my experience with my Breakout 2017 I can recommend 2 main option:
  1. If you have the original pegs...just swap between left and right as they have an angle riser to them, which by default is set downwards. So, if you swap left with right they will be upwards and by that you'll gain significant clearance.
  2. 2" front fork extensions - You can buy those and install. This will lift your front by 2 inches and by that you're not only getting pegs clearance but also ground clearance. I will attach a picture of my bike so you can see how it looks with them installed.
Do Note: You will need to use a longer bolt for the front break cable holder. You see, it is attached under the lower triple-tree and you need to let it go lower as the fork is extended 2" downwards. It is a 60sec bolt replacement and you can use some spacers to close the gap so it can give it the distance it needs compered to its previous position.
Old Feb 6, 2022 | 06:46 PM
  #7524
HKMark23's Avatar
HKMark23
Pre 2018 models have a longer wheelbase than later models. They look great but are not given to cornering as sharply as shorter wheelbase models. Keep this in mind when / if riding group. The pegs aren't actually as much of a concern as ending up on the primary. SXR's suggestions are excellent IMHO and if you wish to address some inherent front end problems even further, find the thread here on front end modifications using Ricor Intiminators and Racetech constant rate springs. I've installed the 2" slugs on my 2014 BO, done the fork mods, changed pegs and added a fork brace too. The BO OEM front end is a pig, sad but true. These mods will completely transform the BO's handling in a decidedly positive way. These are easy DIY mods and worth every penny of the investment.
Old Feb 22, 2022 | 10:42 AM
  #7525
Vince Lopez's Avatar
Vince Lopez
Default Shaved the Tail Lights
Finally shaved the rear tailights and integrated all functions into the Custom Dynamics license plate!
Old Feb 28, 2022 | 01:35 PM
  #7526
Lawrence Dallas Latona's Avatar
5th Gear
Default 2017 breakout chopper "mayhem"
Old Mar 3, 2022 | 05:50 AM
  #7527
dieselbeef's Avatar
dieselbeef
looking for the chrome belt guards..upper and lower..maybe a kit with the chrome pulley cover also? 17 model
Old Mar 7, 2022 | 03:16 PM
  #7528
Hardcandybreakout's Avatar
Hardcandybreakout
6th Gear
Originally Posted by 2014breakout
Does anybody have any suggestio
ns for the best Bolt on Cam shafts for 2014 Hardy Davidson break out? I have vance Hines 2 and the one exhaust and arlen ness big sucker Air intake And a tune
Originally Posted by HKMark23
I did a 3" lift on my 2014 by replacing the stock risers with the stubby CVO risers mounted on 10 degree forward angled bushings. I also have apes. You may encounter tank clearance issues with this method if you have stock bars. A distinct benefit of doing it this way is that the speedo housing remains right in front of the tank gap created by the lift, obscuring it rather nicely.
where did you get the chrome dash from?
Old Mar 15, 2022 | 12:44 PM
  #7529
ATL-HankO's Avatar
ATL-HankO
Default Breakout CVO Front Tires
Good afternoon. I've been reading the numerous recommendations on switching from the 130/60-21 to the 120/70-21 for the regular Breakout with 21-inch tires and was wondering if those same recommendations would apply to the FXSE as well with the standard 130/60-19 tires. Does anyone have a suggestion on a replacement? I've been looking at this one: Metzeler ME888 Marathon Ultra. Thanks
Old Mar 25, 2022 | 10:25 AM
  #7530
HKMark23's Avatar
HKMark23
Its a Blackline dash. I sent it off and had it chromed.
