02 sporty, power at coil no spark
Old Mar 15, 2015 | 05:46 PM
chrisd0729's Avatar
chrisd0729
Stage I
Default 02 sporty, power at coil no spark
I have an 02 Sportster that died last week at bike week in Daytona. It started and ran fine before, rode all day for a few days... Pulled into a parking lot Monday afternoon and it died as I came to a stop. Couldn't get it started again. Got it home and found I have no spark at the plugs when grounding plug wires to the block. Initially thought it was coil and replaced it but, still no start. Don't want to keep throwing parts at it and looked up what to test. I have power in the wht/blk wire to the coil and a solid 12+ volts on the battery. Starter turns over strong but, no spark at plugs. Exhaust smells strong like gas so no fuel problem.
What's my best plan for testing out ignition module? Or is there something else I should check first?
Thanks in advance
Old Mar 15, 2015 | 09:48 PM
run1fsr's Avatar
run1fsr
Unlikely that your problem is the engine control module. Certainly possible, however, they typically do not fail. A Harley Davidson service manual for your model bike will walk you through the necessary steps to troubleshoot the ignition system.
Old Mar 16, 2015 | 08:51 AM
mrfikser's Avatar
mrfikser
if I remember correctly the ignition controller has a light on it that should turn on and off as you turn the motor over.. so pull the cover for the controller and watch... you have 12v to the coil that tells me that you have 12v to the controller...the bell behind the controller that "tells' the controller when to fire may be messed up (it is not uncommon) or the electric eye that reads the gap in the ignition bell may be dirty or bad...no way to tell without taking off the cover and looking...
Old Mar 16, 2015 | 09:04 AM
mrfikser's Avatar
mrfikser
here is a blow up of the parts inside the cover..
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
actually the link is funky... click link and go to OEM Harley parts finder and type In year (click) model (click) and electronic
control module.. roll down and you will see the set up
Old Mar 16, 2015 | 09:33 AM
roundy's Avatar
roundy
How old are the leads? If they are the originals they will be toast by now, mine were.
Old Mar 16, 2015 | 11:40 AM
HOTLAP's Avatar
HOTLAP
^+1, if not google how to check the coils with an ohm meter, also check that the engine is properly grounded to the chassis.
Old Mar 13, 2017 | 02:37 AM
Blowngasketcasket's Avatar
Blowngasketcasket
Hey man have you figured out your issue I have the same problem and I'm trying to figure it out my self. This is a video and run down on my bike also if you look up my username you can see my tread post.. Any help or advice would be awesome!!!...
Old Mar 13, 2017 | 09:15 AM
72 Ironhead XLH's Avatar
72 Ironhead XLH
Old Mar 13, 2017 | 09:18 AM
72 Ironhead XLH
Old Mar 3, 2019 | 08:12 PM
DavincisGarage's Avatar
DavincisGarage
This is happening to a sporty i just picked up. Was the issue solved?
Eowright
EVO
Jun 5, 2018 08:37 AM
Darin Edwards
Sep 18, 2015 01:45 PM
racin45
Sep 24, 2013 09:14 AM
bchrist320
Jun 10, 2013 09:42 PM
zenwarrior
May 19, 2007 11:21 AM
