Installing Torque Cones Question
Old Jul 3, 2012 | 12:23 PM
Voony's Avatar
Voony
Default Installing Torque Cones Question
Hello,
I just got a new set of drag pipes (long story), and I bought torque cones. The installation was easy except that I couldn't put both nuts on the front headpipe's flange. The added thickness of the torque cones wouldn't allow me to do so.
I'm concerned that having only one bolt in the front could become a problem down the road. And the other nuts wouldn't go in fully either.
What do you guys think?
Thanks,
Vincent
Old Jul 3, 2012 | 08:41 PM
Voony's Avatar
Voony
Anybody?
Old Jul 3, 2012 | 08:54 PM
VBdiver's Avatar
VBdiver
Default one bolt on exhaust ?
sounds like a lot of trouble down the road . that's a lot of stress on one stud , plus you will develop a major exhaust leak pretty quick . are you sure the cones are seated properly ?
put some baffles Or at least a lolly pop in those pipes for some back pressure.
Old Jul 3, 2012 | 09:28 PM
Voony's Avatar
Voony
I played with the torque cones for a while to make sure they were seating properly. Maybe I need to go back to it..,
Old Jul 4, 2012 | 08:59 AM
Kenny94945's Avatar
Kenny94945
I'd agree one nut is trouble down the road.
Can you install a longer threaded stud for the nut?
Can you machine the cone/ flange thinner?
Yes, play with the alignment make sure it is seated correctly.
Old Jul 4, 2012 | 09:08 AM
Chiefin's Avatar
Chiefin
Stage I
Something is wrong,,,Both nuts should go on
Old Jul 4, 2012 | 09:57 AM
Voony's Avatar
Voony
Can I put a longer stud? I thought that would require to take the engine apart.
I don't have any machinery to make the cone or flange thinner. I don't even have a garage :-)
Old Jul 19, 2012 | 08:37 PM
nc883's Avatar
nc883
Did you fix your problem? I just installed drag pipes and torque cones with no issues like that.
Old Jul 20, 2012 | 06:24 AM
paulbrad's Avatar
paulbrad
the gasket is tapered and collapsable. have you tried drifting the flange on ?
Old Jul 20, 2012 | 06:25 AM
paulbrad's Avatar
paulbrad
also if youve only got one nut on then you will be leaking and burn your valve seat for sure.
