Post your Dyno results here.
Old Apr 9, 2013 | 06:34 PM
  #41
Imus's Avatar
Imus
That's just sick madnss! You should list out the goodies!
Old Apr 10, 2013 | 11:07 AM
  #42
Madnss's Avatar
Madnss
1992 Sportster owned by Madnss
HAMMER PERFORMANCE Bolt-on 1250 Kit with 30 Degree Reverse Dome Pistons
HAMMER PERFORMANCE Sledge Head Porting Service on XB heads
HAMMER PERFORMANCE CRUSH 600 Cams
HAMMER PERFORMANCE Billet Intake Manifold
Mikuni HSR45 Carburetor
Patriot Defender Exhaust System
Comments: After Ryan got used to his 103hp motor (see below), he came to us and asked for more. We upgraded him to our latest innovative pistons and top-of-the-line head porting. Made a difference, congratulations Ryan!
Bike has a daytona twin tec ignition. It was assembled and tuned by me, 91 octane pump gas was used. It has 10.9 to 1 compression with a corrected compression ratio of 9.3 to 1. It has a rather extremely large intake valve in it. Still have factory rockers and lifters. Dyno pull was done in 4th gear. Bottom end is stock 1992 and has not been opened up. Still have some tuning to do, as you can see its still pulling at 7200/7300. Next tune up we will spin her up to 7500.
Old Apr 22, 2013 | 04:49 PM
  #43
2fast4trouble's Avatar
2fast4trouble
Default HD FortyEight
Here are my dyno results. My 48 has Sik "Berta" Pipes and SE A/C. Use a SERT to tune it on a dyno. It was done at Harley Davidson at Frederick, MD. I think they are good numbers for a Stage 1 upgrade. I am happy with it.
http://www.flickr.com/photos/sst_photography/8673672106/
Here is a pic of the bike with the pipes and A/C:
http://www.flickr.com/photos/sst_photography/8640618543/
Old Apr 25, 2013 | 02:16 PM
  #44
iwantmybeerbackplease's Avatar
I think those are very good numbers for a stage one 1200! My 1212 conversion is getting 83hp also. You must have gotten a great Dyno tune.
-Beer
Old Apr 26, 2013 | 11:11 AM
  #45
HOTLAP's Avatar
HOTLAP
Here's mine;
2007 1200 Roadster with Hurricane flow, SEII slipons, PCV with map supplied by Fuelmoto.
It was a very hot day as you can see 33.47C (about 92F), dyno operator thinks he could have gotten 1-2 more HP if it was cooler.
Horsepower was 76.33 torque was 77.85
[IMG][/IMG]
[IMG][/IMG]
Old Apr 30, 2013 | 05:06 PM
  #46
jlp29's Avatar
jlp29
Finally got my bike back after having cams installed and dyno tuned. Bike is an 04 1200 with no other internal engine mods.
Modifications:
Hammer Performance Impact .560 cams
Patriot defender baffle fully open
Figure machine A/C ( looks like a heavy breather)
TC88A with Rico's "Hooligan" map
Dyno tune - stock cv carb ended up with 48/190 and just over 3 turns out.
Obviously these are "STD" numbers but same bike, same dyno, same operator.
Tuner was real impressed with these #s and actually recommended a mikuni, but this isn't a max effort build.
Old May 6, 2013 | 03:10 PM
  #47
nightster2769's Avatar
nightster2769
Stage II
77hp 77tq
Attached Thumbnails Post your Dyno results here.-920872_308448569285869_202568802_o.jpg
Old May 9, 2013 | 10:16 PM
  #48
OCORtravo's Avatar
OCORtravo
just got my 2013 48 dynoed today.... got pretty good numbers!
81.25 HP
78.30 TQ
Stock internals, PCV w/o O2 sensors, Exotic Choppers "fuelies", DK customs A/C, SE plug wires...
Still pops quite a bit on decel, dyno op said its because the pipes are really short and it will be close to impossible to get rid of all the popping.
Old May 10, 2013 | 03:44 AM
  #49
DK Custom's Avatar
DK Custom
Platinum Sponsor
81.25 HP
78.30 TQ
Thunder Torque Inserts are designed to increase your low and mid range torque, and a side benefit is that many times they will reduce or eliminate decel pop.
Click HERE for more info.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Jun 9, 2013 | 08:53 PM
  #50
Robert Strohl's Avatar
Robert Strohl
Thumbs up 09 Nightster 2500 miles w/ Rineharts and Screaming Eagle Heavy Breather!
The main reason for the dyno was not for numbers but to get it running right. As you can see the A/F was all over the place and the dealership that I had taken it to previously (which I'll never take it to again) had the O2 sensors turned off in the stock MAP that they installed. I'm very happy w/ the numbers and the driveability is night and day compared to what it was. No surging on the highway, crisp throttle response and better gas mileage. I gained almost 20 miles per tank on the tune. That's how crappy she was running. I almost sold this bike w/ all the issues I've had w/ it since I bought her last year w/ 71 miles on the odometer. Now, I'm happy and I love riding her.
