Throttle won't return
Old Mar 25, 2015 | 05:21 PM
Grousehunter's Avatar
Grousehunter
Default Throttle won't return
Good afternoon. I am looking for some help before riding season gets here. The sutuation is as follows: 2006 Road King Classic that I bought last year from the original owner with 6,000 miles on it. Currently it has 15,000 miles. Just prior to the winter I had the dealer install Heritage bars. All good except they were angled back too far. I only road it home from the dealer just before Deer Season. Over the winter I rotated the bars a bit forward and installed Heat Demons. Now the throttle barely returns to idle w the forks turned to the right and the symptom gets worse as the wheel is turned to the left. I have the adjusters on the cables set so the throttle cable just allows the assembly to nearly touch the stop. This required a good bit of adjustment "counterclockwise". The idle adjuster is backed off (clockwise) as far as it will go. The dealer told me the cables would be long enough and I also read that here. At a bit of a loss and will appreciate any suggestions. Thanks.
Old Mar 25, 2015 | 05:52 PM
keithl3030's Avatar
keithl3030
my bike had a zip tie that ran around the brake line and throttle cable just under the handelbar clamp,if it;s too tight it will not work right.
Old Mar 25, 2015 | 06:47 PM
mkguitar's Avatar
mkguitar
the idle cable will pull the throttle closed- adjust it
mike
Old Mar 25, 2015 | 06:48 PM
decencyxdefied's Avatar
decencyxdefied
Good ole' push pull throttle
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Loosen the cable inline tensioner. I think it's on the return side.mmsounds like yours is tight.
Old Mar 25, 2015 | 06:55 PM
Guntoter's Avatar
Guntoter
I had this problem when I installed my bars and the new cables. I had to spend some time zip tieing the cables in just the right place so they did not bind when turning the bars. I did find that after some use and miles I had to un-zip-tie most of the ties to get it still to be smooth. Now it all works fine. Make sure the cables are not being pulled or stretched when you turn the bars, which is probably what is happening. If they are, they will either need re-routed, if possible, or more likely need longer cables. it is dangerous to have the throttle binding, not returning, or worse the throttle being pulled when turning the bars.
Old Mar 25, 2015 | 07:49 PM
chris h.'s Avatar
chris h.
I'd be willing to bet the cables are a hair too short. That could be the reason the bars were pulled close is because the dealer knew that's the only way they'd work.
Old Mar 25, 2015 | 07:52 PM
TWIN CAM 96's Avatar
TWIN CAM 96
clean the cables & grips + lube them
Old Mar 25, 2015 | 07:58 PM
Grousehunter
Thanks for the input. I appreciate it.
dragon78
Nov 13, 2019 10:25 PM
modular
Sep 9, 2013 11:30 AM
rgjujitsu
Oct 17, 2012 03:40 PM
pheur
Aug 12, 2011 08:30 PM
mikeej
Jun 10, 2009 01:11 AM
