Exhaust Performance Question
Old Feb 9, 2016 | 10:07 PM
  #31
Moto Mike's Avatar
Moto Mike
WB, looks like you ordered the rear sprocket that should help! I used Evolution's Industries 30 tooth primary sprocket to tighten up the gear ratio's on my 07 SG, also put Baker Drive train Attitude Adjustor in the primary. The self tightening stock Harley chain tensioner gets to tight and causes problems with the engine and transmission bearings, plus you pick up 3 to 4 pound-feet of torque. Probably too late for your upgrade, good luck with the rear sprocket change, it will help! Saw the EV upgrade in Baggers magazine April 2015.
Old Feb 10, 2016 | 12:55 PM
  #32
Bmusg's Avatar
Bmusg
Originally Posted by WB
I have decent low end power. I am lacking is at speed (70+) bucking and head wind two up. Noticed the stock 103HO, also two up I was riding with made a hiway pass and I knew I didn't have time or the passing power to make the move. Is that to be expected?
Exhaust might help, gearing will help more but keeping up with a 103HO will require more compression and cubes than your 96 has, especially riding 2up into a headwind. Also, I might be wrong but doesn't a 68T rear simply get you to the stock 09-up gearing? Stock, 09-up 96's are over geared and underpowered as well so make sure you do your homework here. Big Boyz head porting has a calculator that you can use to see the differences. It's more involved but you will gain more gear ratio with a 30 tooth front sprocket.
Old Feb 10, 2016 | 01:36 PM
  #33
qtrracer's Avatar
qtrracer
on an 07-08 first order of business is to get the 68t on. Then if more revs are desired then a guy can go 31t or even 30t trans pulley with the bonus of keeping the stock belt fitted. Keep in mind the op has a 255 cam so he may neither need or want more revs than the 68t rear pulley gives.
Old Feb 10, 2016 | 10:06 PM
  #34
WB's Avatar
WB
Not looking to be the fastest or most powerful bike in the pack, Just wanna be able to have the passing power when needed. Thanks for all the replies and help with this problem. Installed new spark plugs yesterday and the power was a night and day difference.. By the way, don't drink drink the Auto-lite Koolaid.. They suck!!!!!!
Old Feb 17, 2016 | 09:11 PM
  #35
WB's Avatar
WB
Got the 68 tooth sprocket installed tonight and took a very short ride,, No highway riding but I can say 1st gear is night and day.. Actually moves off the line without riding the clutch. Torque is their also!!!!! Broke her loose a couple of times when I hammered on it.
Old Feb 17, 2016 | 10:01 PM
  #36
SBates08's Avatar
SBates08
Hmmm told ya. 30T front makes it even better!!!!
Old Feb 18, 2016 | 09:58 AM
  #37
LazySundays's Avatar
LazySundays
Doesn't the op need to recalibrate the speedo now? I would assume that the speedo gets it's info from the ECM on an 08
Old Feb 18, 2016 | 12:20 PM
  #38
WB's Avatar
WB
My Power Vision will take care of the calibration. Just have to make the correct adjustments. Open up your tune (*.pvt file). Under the 'Gear' folder you'll find the 'Speedometer Calibration' table. This table has only one value, that being 'PPU'. Adjust this value slightly one way or the other until your speedo matches your GPS.
Old Feb 18, 2016 | 12:36 PM
  #39
leon anthony's Avatar
leon anthony
I have a 2008 ultra with a 103 stage 2 no problem
Old Feb 20, 2016 | 07:27 PM
  #40
WB's Avatar
WB
Well we took a 200 mile trip today and all I can say is my setup is spot on.. Runs great thru all gears.. Day and night difference.. Not real sure the 103 has an advantage anymore!!!!!
BobbyVera
Feb 13, 2013 07:54 PM
fatboy1729
Oct 23, 2012 12:38 PM
Harley58
Oct 6, 2009 06:25 PM
oricko
Apr 28, 2009 05:19 PM
JoeVFR
Jul 27, 2006 12:42 AM
