Ported polished heads
Old Feb 6, 2017 | 09:04 PM
BigBoreUltra's Avatar
BigBoreUltra
3rd Gear
Default Ported polished heads
I have a 99 ultra classic EFI with a screaming eagle big bore kit installed in it running a power commander three I recently just put some heads on that were ported and polished I cannot get this bike to start what do I need to do
Old Feb 6, 2017 | 09:16 PM
mkguitar's Avatar
mkguitar
valves opening and closing at the right time?
remove the plugs and manually rotate the motor, checking that the valve timing is correct.
then go over you reassembly- injector, plug wires etc
mike
Old Feb 6, 2017 | 09:30 PM
BigBoreUltra
3rd Gear
Hey Mike thanks for the reply. Did the rotation and rechecked reassembly. With these heads I'm assuming that there is quite an increase in air flow compared to stock. I am thinking that I have to recalibrate air fuel and EMC but I am not very knowledgeable about this. I reset the ecm by turning ignition switch on and off three times but no change. Checked and I am getting fire to the plugs.
Old Feb 6, 2017 | 09:43 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the tune will be off but it should at least fire and run.
Old Feb 6, 2017 | 10:01 PM
ROCKOUT Rocker Products
Sponsor
Fuel line reconnected?
Yeah, I know. But a lot of times it's the simple things.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Feb 6, 2017 | 10:17 PM
BigBoreUltra
3rd Gear
[QUOTE=ROCKOUT Rocker Products;15910411]Fuel line reconnected?
Yes. I wish it was that simple. When I pulled plugs it appeared that only the rear cylinder was getting fuel. So I am going to start with checking fuel line and vent in morning. If I don't find anything hopefully someone might have run into this before and will S pread the knowledge. I'm really thinking that the extreme change of air flow will probably mean recalibration which I have no experience with
Old Feb 6, 2017 | 10:37 PM
ricktherocket's Avatar
ricktherocket
is it firing at all?
Old Feb 6, 2017 | 10:53 PM
BigBoreUltra
3rd Gear
Default H
Yes. Firing good
Old Feb 7, 2017 | 05:25 AM
G E E's Avatar
G E E
Spark plug wires backwards ??
Old Feb 7, 2017 | 09:57 AM
senna's Avatar
senna
It has nothing to do with the fact that your heads are ported.
The big three are fuel, spark and compression. Make sure you have all three.
XLDutch
May 8, 2013 01:49 AM
jrfernandez7
Jul 1, 2009 12:34 PM
6o66er
Apr 3, 2008 03:26 PM
saweet96
EVO
Sep 12, 2007 09:21 AM
k2rmx.rob
Apr 6, 2006 10:55 PM
