Ignition key removal on 06 SG
Old Nov 24, 2008 | 08:36 AM
masterblaster's Avatar
masterblaster
Now ya tell me, duh, thanks for the info on the fix.
Originally Posted by iclick
It is really very easy once you get the hang of it, and you can pull it off in one second. You don't really need a screwdriver, as stated in the manual, if you have small fingers and can push the tab under the switch with a finger while turning the ignition key CCW. Start at the Lock position, push up on the tab with a finger or small screwdriver blade, turn the key CCW about 60°, and pull the switch **** up and out.
Make sure you remember the correct position of all the switch parts for reassembly and don't attempt to move the switch to any other position unless all parts integral to the **** (2 collars and a nut) are in place. I made the mistake of inserting the switch **** without the collars and nuts by mistake to move the switch off Lock to move the handlebars, and got the internal mechanism out of whack. I thought I would have to trailer it to the dealer, but using a flashlight and flat-blade screwdriver managed to get the switch mechanism back in alignment. There are two moving parts to the switch mechanism inside the shaft hole, and if they get out of alignment the **** won't fit properly and the switch won't work.
The point is that you may need to insert the switch **** in to unlock the handlebars to re-attach the fairing switch cap, as it is a tight fit. Just make sure everything is in place (collars and nut) before attempting it.
Old Nov 24, 2008 | 08:58 AM
Cowracer's Avatar
Cowracer
Dont forget, You HAVE to turn the key CCW when installing it too.
Turning the key CCW retracts the locking pawl. All pushing the button does is allows the key mechanism to rotate ccw past lock.
I fought installing my ignition for an hour before I figured that out.
Tim
Old Jan 4, 2009 | 02:31 PM
wietrzak's Avatar
wietrzak
Stage II
Default Thanks!! You saved me a ton of frustration.
Old Jan 4, 2009 | 03:03 PM
wietrzak's Avatar
wietrzak
Stage II
Wink Thanks!! You saved me a ton of frustration.
Thanks to Iclick I think I just saved a ton of time and a visit to my local dealer. The instructions for reinstalling the Ignition switch were dead on.
Old Jan 15, 2011 | 04:06 PM
merrittbc's Avatar
merrittbc
Stage I
REMOVAL OF IGNITION SWITCH for 05 ELECTRA-GLIDE CLASSIC
with the KEY inserted, turn SWITCH to the accessory position.
push tab on bottom left side of switch, pushdown switch with the KEY. at same time turn KEY counterclockwise and it pops right out. i had no spring and no special tool was needed. went back together like a charm.
Old Jan 15, 2011 | 10:01 PM
silverado636's Avatar
silverado636
I went on youtube and found a video of a guy doing this. Worked great for me.
Speleo
Jul 20, 2016 12:55 AM
Spatenkopf
EVO
May 30, 2015 12:25 PM
scootryder
Apr 22, 2010 04:16 PM
gnafin
EVO
Nov 1, 2009 09:22 AM
2006ultra
Apr 4, 2006 12:58 PM
