Heel toe shifter
Old Sep 4, 2017 | 08:40 PM
e11charlie's Avatar
e11charlie
Default Heel toe shifter
So I want to remove the heel shifter portion. Just don't like it and it's just in the way for foot positioning. I have been searching for solutions to what I need. What I am running into is if I remove the heel shifter I want to move the toe shifter out to where the heel one was sitting on the shift shaft. Problem is the toe shifter where it's at keeps the shaft in place. I've thought about cutting off the heel shifter all the way down then just swap the two. I don't want to destroy original parts. Other than finding one at a junk yard do they make an option for this? Something with the splines for the shaft. Feel like I'm way over thinking this ****.
Old Sep 4, 2017 | 08:43 PM
DaddyKnuck's Avatar
DaddyKnuck
Find a piece of the correct ID tubing and cut to length.
Old Sep 4, 2017 | 08:48 PM
e11charlie's Avatar
e11charlie
**** me that simple. Don't know why my mind wasn't going there. Thank you sir.
Old Sep 4, 2017 | 08:52 PM
WoodButcher66's Avatar
WoodButcher66
I put one of these on my bike.
http://www.kuryakyn.com/products/71/...ver-eliminator
Old Sep 4, 2017 | 09:06 PM
e11charlie's Avatar
e11charlie
**** been looking at this for two days. Just answered my own question. Took the shifter peg off and just put one behind the other.
Old Sep 4, 2017 | 09:10 PM
e11charlie's Avatar
e11charlie
Originally Posted by WoodButcher66
That's it! Probably get one of those. Don't like the way my solution looks.
Old Sep 4, 2017 | 09:44 PM
mchertel's Avatar
mchertel
Why does there have to be anything behind the toe shifted. Can't it just be tightened down on the spline in the right position?
Old Sep 5, 2017 | 04:30 AM
grbrown's Avatar
grbrown
Talking
I think that's called lateral thinking!
Old Sep 5, 2017 | 06:18 AM
heavymetalthunder's Avatar
heavymetalthunder
I use black heater hose from a auto parts store.
Old Sep 5, 2017 | 07:44 AM
e11charlie's Avatar
e11charlie
No it keeps the shaft from sliding side to side. There's a plastic spacer in between both levers and the engine body but with out the second lever it moves in and out.
