Headlight, Nacelle Removal Help Needed.
Old Jun 15, 2007 | 12:10 AM
ROBSREDFORD's Avatar
ROBSREDFORD
Default Headlight, Nacelle Removal Help Needed.
I am doing a chrome front end and lowering, Got the wheel off fine..but the headlight and trim ring is whoopin my a**. Please explain to a dumb country boy what to do. I don't even have the light out yet. I removed the screw on the very bottomof thetrim ring and itwill pull out a lil at the bottom and will spin around, was i supposed to remove the light first..help a fellow out here. Thanks rob
Old Jun 15, 2007 | 12:15 AM
BigDaddyMike's Avatar
BigDaddyMike
Default RE: Headlight, Nacelle Removal Help Needed.
1.GET a HD service manual!
2. Removethe bottom screw. Take the trim ring off. Remove the 8 screws holding the headlight assembly in(not the headlight aiming screws!). Depending on what bike youre working on, the instructions differ at this point. Refer to Number 1
Old Jun 15, 2007 | 12:30 AM
ROBSREDFORD
ordered the manual today, just impatient trying tio get lowers to chrome shhop
Old Jun 15, 2007 | 01:01 AM
TexasRedneck's Avatar
TexasRedneck
The outer ring is a friction fit as well as havin' a retainin' screw. Grasp firmly from the area by the removed screw, pull out firmly. 'Bout the time yer skeered 'bout bendin' it, it'll come free.
Old Jun 15, 2007 | 01:39 AM
Dave_E's Avatar
Dave_E
Go back and read bigdaddy's post again.
Old Jun 15, 2007 | 01:46 AM
TexasRedneck
ORIGINAL: ROBSREDFORD
I did.....an' mah response stands. Ah'll git ya a copy of "readin' comprehension fer yankees" in the mail tomorrow.....
<g,d&rlh>
Old Jun 15, 2007 | 08:53 AM
jbhawley's Avatar
jbhawley
OK...i am a bit confused...
You are lowering your front end and< i assume putting on chrome fork lowers...but you dont have a manual and you dont know how to remove the headlight. STOP..
Run Forest Run.
Buy the manual, before you do ANYTHING ELSE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 15, 2007 | 09:17 AM
FLHT's Avatar
FLHT
ORIGINAL: jbhawley
Run Forest Run.
I've got to agree with this. If you cant get the headlight out STOP!!!
Old Jun 15, 2007 | 12:35 PM
ROBSREDFORD
Thanks guys, no trouble with engine and trans, just headlight ring was afraid i was gonna break it.
Old Dec 16, 2007 | 05:42 PM
Kbore's Avatar
Kbore
Default RE: Headlight, Nacelle Removal: EASY when you know how.
I have a manual and I had to take off the headlight Nacelle.Its not rocket science, but if you haven't seen the friction clip in the top of the trim ring,it is amystery.
How to remove the Headlight Nacelle headlight trim ring on a '02 ROad King FLHR
Remove the phillips on the bottom center of the Headlight trim ring/ bezel.
Pull the bezel straight up- dont rotate it- dont swing it out away from the headlight- pull straight up toward the ceiling. THe ring has a spring clip male piece that slides intoa femaleslot on the HL bucket. It does not come out easy but apply some umph and it will come. If you break it, you could probably make one from a piece of welding rod.
THen, as the manual says, loosen the two nuts on the top of the nacell. You dont have to take them out but loosen them to allow some clearance.
To remove the riser cover (after taking out the 2 phillips under the steering lock lock/ unlock bezel (pry the bexel out with your finger nail) you have to split the (remove it). Its only a 5 minute job. To split/ remove the nacelle (after the 4 acorn nuts are removed and the highway light bar is sitting on the (well protected) fender, you have to raise the riser cover high enough for the nacelle top bosses to clear- this is done by loosening the rear bolt you can see from the front of the nacelle.
I only posted this because the manual did not show the clip, and it took me a whiloe to discover how to do it.
Peace,
KB
clackavosticus
Mar 31, 2015 07:34 AM
NiteOwlNY
2014-2024 Touring Models
25
Sep 16, 2014 07:08 AM
Texankirk1
Electrical/Lighting/Alarm
Jan 22, 2014 08:10 PM
diflow
Apr 28, 2012 10:19 PM
Lawdawg
Jul 8, 2006 03:29 AM
