Performance baggers
Old Jun 12, 2020 | 08:03 PM
  #701
JonnyVegas's Avatar
JonnyVegas
I'd say wait for RWD, did they give an ETA ?
Old Jun 13, 2020 | 08:37 AM
  #702
crtman21's Avatar
crtman21
unfortunately, they didn't. :-(
Old Jun 13, 2020 | 02:46 PM
  #703
crtman21's Avatar
crtman21
Originally Posted by Dynaglide92
It’s a Rushmore rg. I kept the ignition along with the nacell
Hey @Dynaglide92 I'm finally getting around to installing my bars and gauge relocation. What wrap did you use to cover all your wires?
Old Jun 15, 2020 | 02:59 AM
  #704
crtman21's Avatar
crtman21
Finished up the bars today. Ended up going with the 14" IMZZ Elite Dive bars. Saved a few hundred and I'm really happy with them. nice and sturdy. They were a little narrower than I expected, but I like them. It'll make for splitting lanes a little easier. My arms are parallel to the ground, which I think will be really comfortable. Initially I was thinking about getting the riser/bar setup with the raptor plate which would've made the bars about 15". I'm glad I went with the 14 though. I may mess around with the gauges a little to see if I can find a better spot for them. I put them on the back of the bars, because initially on the front I thought they may interfere with the gas tank lid and filling it up, but I can't see the whole gauge (not that it's entirely necessary), but I also can only see half of the infotainment screen. I need to do some nacelle "fab work" in order to clean up the forks and wire work. for now, I stuffed all the wires in the fairing mount, but it's still not to satisfaction. I did find a blank nacelle that I may get to see if it'll work or modify the original nacelle which would clean up the area around the ignition switch.
Old Jun 15, 2020 | 06:35 AM
  #705
HighLiner's Avatar
HighLiner
Looks good. Could always go the ignition switch delete route!
Old Jun 15, 2020 | 07:22 AM
  #706
crtman21's Avatar
crtman21
Thanks. Ya. I thought about that too.
Old Jun 15, 2020 | 12:59 PM
  #707
blueangel73's Avatar
blueangel73
I used something like this. I believe it was the half inch, it expands pretty well to get over the connectors, some of the larger ones did take a little finessing.
Amazon Amazon
Old Jun 18, 2020 | 11:18 AM
  #708
gartec81's Avatar
gartec81
Mjk swingarm, hpi exhaust, knee cutouts, inverted.... some serious coin thrown at this one
Old Jun 18, 2020 | 11:20 AM
  #709
Dynaglide92's Avatar
Dynaglide92
techflex! 3/8 should do the trick I went 1/2 and had some extra room
Old Jun 18, 2020 | 11:21 AM
  #710
Dynaglide92
that tribar gotta go ! Other then that 🔥
