Performance baggers
Old Aug 28, 2020 | 10:12 PM
  #921
Chad1200's Avatar
Chad1200
Originally Posted by kyleMB
2015 police road king
12" westcoast t-bars
13" fox shocks with rebound adjustment in the rear
Patriot springs up front
A borrowed Saddlemen step up
SE 254 cam
SE breather
V&H Pro Pipe
Really nice set-up. Clean and simple.
Old Aug 29, 2020 | 01:40 AM
  #922
DynaKid94's Avatar
DynaKid94
SE 254 cam
SE breather
V&H Pro Pipe
Killer bike man, clean and simple.
Old Aug 29, 2020 | 08:17 PM
  #923
jyd83's Avatar
jyd83
Question about hand controls- Anyone know if you can get "moto" style clutch/brake levers that use the stock master cylinders? Looking for something similar to the ones pictures on the Kraus website but hoping to avoid the large cost of the full setup.
Old Aug 30, 2020 | 11:35 AM
  #924
gartec81's Avatar
gartec81
flo motorsports harley mx levers
Old Aug 30, 2020 | 08:26 PM
  #925
jyd83's Avatar
jyd83
[QUOTE=gartec81;19366526]flo motorsports harley mx levers
Thanks man, that's exactly what I was looking for!!
Old Aug 30, 2020 | 08:34 PM
  #926
Bafflingbs's Avatar
Bafflingbs
Well, I did it. I ordered a Man-O-War crank, to calm my fears. I’m also going to do a Trask clutch basket, cam plate and oil pump. Might of been cheaper to just buy an S&S 124” I already did the Darkhorse sprocket and beefed up my clutch with a 9 plate kit. Trying to make my 110” bulletproof.
Old Aug 30, 2020 | 10:35 PM
  #927
gartec81's Avatar
gartec81
no problem
QUOTE=jyd83;19367402]
Old Aug 31, 2020 | 10:31 AM
  #928
SoCalDyna2015's Avatar
SoCalDyna2015
personally wasn’t a fan of the Flo levers. A bit flimsy, lever is narrow and cuts into fingers compared to wide OEM blade, and the adjustment mechanism moves the usable part of the lever towards the outside about 1”. This is very counterproductive to a “reduced reach” lever.
I ended up cutting and shaping my oem levers, then bent towards the grip an inch to get engagement with reduces reach.
Old Aug 31, 2020 | 10:37 PM
  #929
gartec81's Avatar
gartec81
nice job on your levers. I did the same on my dyna I had
Old Aug 31, 2020 | 11:27 PM
  #930
rcrankin's Avatar
rcrankin
I think at some point you will stumble across what is causing the neutral rattle. You could be the hero of many. Let us know how the Trask clutch basket works out for you.
Thanks,
Rob
