No cruise p5077 code
Old Dec 28, 2017 | 09:10 PM
Westridge81's Avatar
Westridge81
1st Gear
Default No cruise p5077 code
My cruise isnt working at all on my 2011 road glide ultra. The engine light comes on after about three minutes of running the engine or riding and it’s throwing a code P5077. Has anybody else had this problem with this code? What did the problem end up being?
Old Dec 28, 2017 | 09:24 PM
MURPHCC1's Avatar
MURPHCC1
check you brake light switch ......
And your cruise control switch
Old Dec 28, 2017 | 09:53 PM
Westridge81
1st Gear
If it was the brake light switch the engine light wouldn’t be on. The 5077 code is specific to the cruise control.
Old Dec 28, 2017 | 09:55 PM
Fireball Jack's Avatar
Fireball Jack
Do you mean P0577? any mods to the bike?
Old Dec 28, 2017 | 10:04 PM
Westridge81
1st Gear
Yes my bad p0577 too high cruise control input. Only stage one but that was done years ago
Old Dec 29, 2017 | 06:25 PM
btsom's Avatar
btsom
Anything odd with your speedo or odometer? I don't know if input "too high) has to do with pulse rate but if it were mine I would start looking at vehicle speed sensor and its connectors. There used to be a lot of flaky speedos, non cancelling turn signals, and cruise problems that traced back to metal contamination on VSS. Some people cleaned and reinstalled them and all was good, and others just replaced them. At least a place to check. Has the bike had a bath using a high pressure washer or a garden hose? Water can get into connectors and cause all kinds of weirdness.
Old Dec 29, 2017 | 06:53 PM
Westridge81
1st Gear
Speedo and tach are working fine. I’ve put a good 10000km on the bike since the cruise crapped out. It happened when I was riding about 15km a day on a rough gravel road for a few weeks. I’ve taken the switch apart and cleaned everything really good but it didn’t help. I know there is a road map to diagnose the issue but you pretty much need to be a Harley tech to access the appendix’s for the shop manual
Old Dec 29, 2017 | 08:20 PM
14GuineaPig's Avatar
14GuineaPig
From 2011 Elec Diag Manual for DTC P0577
Old Dec 29, 2017 | 09:50 PM
Westridge81
1st Gear
That’s exactly what I was looking for I’ll probly start on it in the next week or so
jblass
Jul 17, 2018 10:28 AM
tjcaron
Sep 8, 2013 07:54 AM
FatTony
Jul 11, 2012 07:45 AM
grummie
May 4, 2012 06:40 AM
TerryLe
May 14, 2011 05:39 PM
