Street Glide Antenna Removal
Old Jun 22, 2007 | 06:49 PM
user 37474839's Avatar
user 37474839
Default Street Glide Antenna Removal
Is there any special procedure for removing the antenna on an 07 Street Glide? I'm wanting to take it off so I can cut it down from the bottom part.
Thanks!
Old Jun 22, 2007 | 06:58 PM
monte64's Avatar
monte64
Default RE: Street Glide Antenna Removal
There is a small allen head set screw at the bottom, right where the ant. meets the taper. When you cut to length make sure you take the paint off with steel wool or sandpaper to get a good connection. I cut off 15" with no problem with reception.
Old Jun 22, 2007 | 07:03 PM
dionne51's Avatar
dionne51
Cut it to the same length as your car antenna, I think it is either 30 or 36". You will lose no reception at this length other than CB strength loss.
Or just get the shorty rubber antennas for the ultimate sleek appearance.
Old Jun 22, 2007 | 09:29 PM
user 37474839
Good tip on the allenhead screw..didn't even know it had one.
I was wondering though about how the base of the antenna detaches from the frame. Is it just threaded in there or is there some other fastener? I tried grabbing the base and turning it but it didn't want to budge.
Old Jun 22, 2007 | 10:07 PM
dionne51's Avatar
dionne51
I believe there is a nut on the underside.
Old Jun 23, 2007 | 12:02 AM
Timex's Avatar
Timex
Back out the set screw, and thread off the antenna base.
ORIGINAL: celtlion
Old Jun 23, 2007 | 10:50 AM
truegentlemann's Avatar
truegentlemann
From: i live outside Omaha Ne on the Iowa side in the Loes hills, some great places to ride
i had installed the rubber antenna under my front fairing and have no antenna showing.
it is just tystraped on to wiring and pluged into the radio.
Old Jun 23, 2007 | 11:48 AM
StreetGlide2006's Avatar
StreetGlide2006
I just installed a Tune Trapper on my 06 SG. Just removed stock antenna and grommet and installed a plug like on the right side. No more antenna and great reception. I love it!
Ride Safe,
Mike
Old Jun 23, 2007 | 12:01 PM
notorious's Avatar
notorious
You know I kinda like my eye-poker-tini. Keeps those less than knowledgeable away, sorta street glide self defence first strike capability thing happening there.
Old Jun 23, 2007 | 12:20 PM
Smurfshxt's Avatar
Smurfshxt
I have smoked myself in the face a 1/2 dozen times on that thing so far......and my GF hit herself in the eye last week.....wish i was that antenna sometimes....
jrdfatboy
Jan 7, 2015 02:55 AM
sas33
Nov 11, 2007 07:37 AM
Rick 547
Mar 28, 2007 05:05 PM
jcfolsom
Mar 5, 2007 02:35 AM
BLACK AVENGER
Mar 28, 2006 06:41 PM
