oil drip
Old Apr 18, 2021 | 03:48 PM
Kenny Right's Avatar
Kenny Right
Default oil drip
2013 ultra limited, stage 2, cams and air / exhaust. Went for a ride today and started smelling something new. Stopped for a break and noticed a spot of oil on the engine cover below the air intake. I ran my hand around the backside bottom of the intake cover and got oil. Not a lot, but enough to concern me. I'd appreciate any ideas from one and all. I have not yet removed the cover to look around. I will get to that. So, thoughts???
Old Apr 18, 2021 | 03:54 PM
hardheaded's Avatar
hardheaded
Breather oil from the breather hose running into the air filter in the air filter housing. Do a search on here and there are many solutions to the problem. Take the cover off and it will be obvious what the problem is.
I just put a T in the hose's and ran the other hose to the ground. Problem solved !
Old Apr 18, 2021 | 04:30 PM
SMR65's Avatar
SMR65
As they say, they all do that. Maybe not all, but many do. There are different ways of fixing the problem, many on this forum will explain how. It will not hurt the motor, but will make a mess of the right side of your bike.
Old Apr 18, 2021 | 04:34 PM
pgreer's Avatar
pgreer
Routing the the breather outside the intake is something that should be done to avoid hot oil form entering the combustion chamber, and gumming the throttle plate and IAC valve, not to mention all the carbon on the piston tops. As mention previously, there is a lot of discussion on the forums about this topic, but how it is accomplished varies by individual as well as the type and brand of air cleaner you are running. But, I still run the oil about 2-3 hashes below the full mark on the stick, and that does seem to help.
Paul
Old Apr 18, 2021 | 04:51 PM
Screamin beagle's Avatar
Screamin beagle
Wonder if the breathers were replaced when the motor upgrades were done? Just one possibility...oil level too high. Like these other guys said, its time to run an external breather. You can make your own with some hose, a small filter or catch can and a couple hose clamps. Theres also dk customs...they have kits with all the pieces all in package ready to go, just depends on your level of mechanical abilities.
Old Apr 18, 2021 | 05:39 PM
Ssitruc's Avatar
Ssitruc
https://www.hdforums.com/forum/touri...-included.html
a good thread on the solution, with a lot of different ideas... mine is like posts 627 thru 631'ish
Old Apr 18, 2021 | 05:49 PM
miner999r's Avatar
miner999r
Seems to be a relatively common thing. My 2010 Ultra did it. As the fellow above posted lots of threads on the subject. If you get a lot of oil blow by (like it makes puddles) I would be getting concerned. I had a lot and I ended up with an engine rebuild due to a scissored crank. I saw a youtube vid somewhere that said a bad crank will exacerbate the problem. (check for metal bits in the oil when you change it, mine had lots of bronze in it from the crank thrust washer) My rebuilt motor runs very clean now with no more drips.
Old Apr 19, 2021 | 01:33 PM
deadhawg's Avatar
deadhawg
Common issue, not really a big deal other than being messy. Easy fix. https://www.dkcustomproducts.com/pre...dis-brt-tc.htm
Sorry, link is for M8 bikes, but they also have kits for twin cams.https://www.dkcustomproducts.com/bre...ms-c21-221.htm
Old Apr 19, 2021 | 01:51 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
My thought is, remove the cover and look around, put a little effort into solving your problem.
Old Apr 19, 2021 | 04:47 PM
Kenny Right
Thanks everyone, and yes, I will make the effort to look around myself, but there is a lot of experience here and I'd be foolish to start poking around uninformed. Thanks again to one and all.
djs
Milwaukee Eight (M8)
32
May 11, 2018 04:37 PM
Bigdave12768
Jul 23, 2013 04:16 PM
Slyonsppd
May 31, 2013 10:46 PM
VTGlideRider
May 19, 2012 05:34 PM
kevdog
Aug 14, 2006 10:21 AM
