Engine Swap ?’s
Old Oct 10, 2023 | 11:30 AM
matt_eglide's Avatar
matt_eglide
Default Engine Swap ?’s
I have a line on a killer deal for a Screamin Eagle 103 out of an 03 Anniversary SE Road King; this is the stroker kit they bolted on the stock 88” case with the larger jugs, higher comp pistons and SE ported heads…will the stroker crank/flywheel assembly, pistons and cylinders bolt into and into my stock 96” case on my 07 EG Standard without major mods? Looking to build a little 100+HP engine on a budget…Thanks!
Old Oct 10, 2023 | 12:59 PM
eighteight's Avatar
eighteight
The 88 to 103 kit has a 4 3/8" stroke
Your stock 96" has a 4 3/8ths stroke
Old Oct 10, 2023 | 01:11 PM
M Oclaf's Avatar
M Oclaf
And?
Old Oct 10, 2023 | 01:13 PM
eighteight's Avatar
eighteight
Originally Posted by M Oclaf
And?
So he gains nothing by splitting the cases and swapping cranks........
Old Oct 10, 2023 | 01:17 PM
matt_eglide
Got it, same stroke just slightly larger bore to get to the 103” displacement. Good news!
Old Oct 10, 2023 | 01:21 PM
eighteight's Avatar
eighteight
Correct.
You could accomplish the same by boring your existing cylinders
Old Oct 10, 2023 | 01:27 PM
matt_eglide
Planning to upgrade to Timken bearings in my current case, upgraded and welded crank and a Darkhorse compensator. The 103 jogs, pistons and SE heads will all bolt on. The ported heads alone are worth the price of the engine I’m getting. Also comes with a SE cam plate and larger oil pump.
Already have SE-255 cams in my bike and also a larger 58mm throttle body/intake manifold ready to go on.
Hoping for 100+ HP and 100+ torque.
Old Oct 10, 2023 | 01:29 PM
matt_eglide
Correct.
Got it, however the SE heads are alone worth more than what I’m paying for the engine. Cylinders and pistons are in great shape so should be a simple swap over, the entire engine was removed with under 10,000 original miles and has sat since.
Old Oct 10, 2023 | 01:50 PM
eighteight's Avatar
eighteight
^ Sounds like a plan , now that we have the "rest of the story"
Old Oct 10, 2023 | 02:56 PM
lp's Avatar
lp
Sounds like you got it handled. Curious on how it turns out.
