Steering stabilizer
Old Feb 20, 2024 | 11:53 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by clevelandpat1960
After replacing front stock wheel/tire with a 21 inch, I've noticed a little shake in the forks etc.
Under what riding conditions, and what do you mean by "a little shake in the forks etc"?
I'm not saying I'll have the answer. Different conditions and different symptoms can run one down different diagnostic trails though.
Old Feb 20, 2024 | 01:58 PM
TriGeezer's Avatar
TriGeezer
If you are hell bent on a stabilizer, the HD TriGlides come with a stabilizer. I don’t know if they would fit your bike. And I take no responsibility for the performance on your bike that may result in equipment damage, injury, and or death.
Old Feb 20, 2024 | 02:13 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Here you go.
Ref:5
83808-09A
DAMPER,STRG,ASSY
Price: $601.07
Plus about $100 more or so for the brackets, nuts, spacers and bolts.
Old Feb 20, 2024 | 04:29 PM
gartec81's Avatar
gartec81
I have one. It's to prevent any high speed action just like another other fast paced motorcycle on the market has or can be installed.
im 4 over suspension in front from 2+ tubes and cartridges with +2 drop trees in concunjtion with 14.25 rear shocks. I mounts under lower triple tree and bolts to left side of frame legs.
Steering dampner most definitely makes the ride better if your really getting after it with heavy lean angles on a big *** bike. I also have solid rear isolators installed so it locks my swingarm in place with mo more wiggle from the crappy harley rear isolators.
my dampner is not to band aid anything. . Just to have a proper set up.
you may need to look up "the missing link" and buy it, then get your motor/chassis aligned.
21" up front without suspension, alignment and such could definitely be making funky responses in the riding experience. It also could be a loose rear eyelet or over tightened rear shock. Miss matched tire treads etc.
Old Feb 21, 2024 | 07:42 PM
Ghetto blaster's Avatar
Ghetto blaster
gartec81, your bike is cool as hell, OK, carry on.
Old Feb 22, 2024 | 12:13 AM
gartec81's Avatar
gartec81
thanks @Ghetto blaster much appreciated
Old Feb 22, 2024 | 10:22 AM
ANIMAL03's Avatar
ANIMAL03
Your bike is badass , you got a link to that stabilizer.
Old Feb 22, 2024 | 02:40 PM
foxtrapper's Avatar
foxtrapper
Looks like a Twin Power damper.
​​​​​​https://www.jpcycles.com/product/twi...ku_id=10067755
Old Feb 22, 2024 | 06:17 PM
gartec81's Avatar
gartec81
clevelandpat1960
Jan 25, 2024 06:40 PM
Ultra Classic Sal
Wheels/Tires
32
Dec 11, 2023 08:51 AM
KellyAnne
Jun 17, 2016 06:47 AM
fjoh
Oct 20, 2015 10:36 PM
eric91379
Apr 21, 2008 07:43 PM
