Oil Relocation kit
Old Mar 2, 2024 | 08:50 AM
gonemad's Avatar
gonemad
Originally Posted by Mongo1958
Thanks you for the photos, I like the idea of shorter tubes and a downward looking oil filter so I can fill the oil filter during installation. This will also be behind my lowers and out of sight as well. OK, I now have a plan. Thanks again Cornpipe.
Judging from the ’22 Road Glide Special I just sold, with installed factory fairing lowers, I don’t think it will fit with lowers.
Old Mar 2, 2024 | 08:52 AM
702's Avatar
702
Is there a provision for the clutch cable on the newer Touring and Softail bikes for the downtube version?
Old Mar 2, 2024 | 08:57 AM
Mongo1958's Avatar
Mongo1958
I will find out. Thanks
Rounders's Avatar
Rounders
In theory filling filter sounds nice. But your engine still has oil in it and is coated. You are draining oil pan not engine when doing dry sump
Look at autos, look at all the bikes doing just fine
This relocation is not as extreme as the ones where they put filter to rear of bike. And maybe not all that different than some brands of oil cooler in terms of stressing pump.
until I saw pic I thought it was one where the put oil filter by saddle bag.
So the value of this is no mess for changing oil filter??
Old Mar 2, 2024 | 09:01 AM
Rusty Springs's Avatar
Rusty Springs
Originally Posted by Cornpipe
Mongo I have two of their oil filter relocation kits and love them. There are no issues running these components and I opted for the front frame down tube mounts. I didn't care for the kits that route back to the passenger peg/floorboard.
Those look good.
Old Mar 2, 2024 | 09:06 AM
gonemad's Avatar
gonemad
The clutch cable and adjuster are on the right side (brake side) down tube on current touring frames.
Old Mar 2, 2024 | 09:07 AM
Cornpipe's Avatar
Cornpipe
Veteran: Reserves
Originally Posted by Rusty Springs
Those look good.
Thanks plus they are out in the air stream which can't hurt reducing some heat.
Old Mar 2, 2024 | 09:08 AM
Rounders's Avatar
Rounders
Probably not an issue,but are you more protected behind fender at base of engine then hanging off side?
702's Avatar
702
OK thanks, it's on the left side on my 22 Heritage.
Old Mar 2, 2024 | 09:11 AM
Highway Handler's Avatar
Highway Handler
It does not stress the oil pump anymore than a larger oil pan stresses the pump.
You are over thinking it…
