I am the one? You are such a blow hard. Have you actually hooked a digital volt meter on a bike, to see it drop when applying brake lights? I have my doubts at speed. Some people used to like analog meters because it will catch deflection. But I have not seen one in many years other than meggars, and I think those have gone digital.
Problem with electrical threads is guys like to sound smart. Your area of electrical is piddly little ****. And you accuse me of dragging the thread out.
I think the plug in meter could be an interesting tool, you won't know how accurate it is until you plug in and compare to meter. I suspect way over thinking the draw from the connections. This aint some time little electrical filter you are monitoring with an oscilloscope. its not like it is a lot of money, and you can have more than one tool in your tool box.
I personally would be very careful about riding a bike that I thought might be spiking. You could damage electrical components. which is why I keep asking if bulbs are burning out, that can be a sign.
This thread has ben going on for over 2 weeks.. I didn't get involved until 2 days ago.. Who's the blowhard??
Will do. Between work and a nasty golf habit it hasn't gone as fast as I had hoped. I honestly think it'll only be an hour to an hour and a half to get it all back together. Just want to make sure I do everything correctly.
Does anyone know the amount of oil that goes in the primary after having the entire cover off?
Read your service manual, it will tell you the correct amount. However, fill it as shown below and you will be good to go. Of course I am sure others will chime in with their wisdom.
NOTE:
The above information, while credible, is worth what you paid for it and should not be considered gospel.
Do due diligence, research and have a H-D Field Service Manual before working on your bike.
You will probably have many opinions and suggestions presented; make sure you research the person providing the helpful information as there are some who provide good information that is useful and some who speak out of other orifices with gibberish. You will figure out this quickly.
NOTE:
