CD player skips
Old Dec 1, 2005 | 03:55 PM
06glide's Avatar
06glide
Default CD player skips
Hi all,
I have a 2006 Street Glide, fitted with the Harman/Kardon stereo system that skips regardless of a regular CD or one that I burned.
I have also downloaded the upgraded software from HD to show version 7.8.0 on my display. I was curious if other owners are experiencing any problems like mine. I have noticed that with two different CD's they have skipped on the 3rd track, but otherwise it will cut out and pick up further down the track.
thanks,
Bert
Mayland
Old Dec 1, 2005 | 04:42 PM
Bibleman's Avatar
Bibleman
Default RE: CD player skips
I have an '06 Ultra with the new HK stereo.
I have played mutiple burned CD's, some of which are MP3 CD's with over 150 songs per CD, and they all play flawlessly. Not a single skip.
I would have a chat with the dealer. Something is not right.
Old Dec 1, 2005 | 05:14 PM
solorider's Avatar
solorider
My '06 Street Glide's CD player skipped like crazy one night while cruising down the highway doing about 80 mph. When I slowed down below 70 the problem went away. Also, it hasn't skipped since that night. Sounds like you have a warranty issue there.
Old Dec 1, 2005 | 07:53 PM
RyanMC1's Avatar
RyanMC1
6th Gear
I have an 06 ultra and it also started to skip. If you go to the Harley Davidson web site and go under the new radio section there is a download that you can burn to a cd. You can then put it into your cd player and it will perform an upgrade. If you want to you can also go to the dealer for them to do it.
Old Dec 2, 2005 | 01:20 PM
06glide's Avatar
06glide
Thanks for the advise guys, I'll have to take the bike up there soon and have it checked out. Until then come on springtime....
Bert
Maryland
Old Dec 2, 2005 | 01:29 PM
KBES BAGGER's Avatar
KBES BAGGER
ORIGINAL: solorider
Mine does the same thing. It does it all the time though, any time I get up around that speed it just skips like crazy. I finally got my other bike out of the shop so the SG is going in now.
KB
Old Dec 2, 2005 | 01:35 PM
nmfxstc's Avatar
nmfxstc
Mine is an '05 stock CD player...only skips I noticed was with burned Ds that exceeded about 15 tracks (90%) of a CD...otherwise, no probs.
Old Dec 2, 2005 | 04:11 PM
bonzo2's Avatar
bonzo2
On the 06 Ultra's make sure the speaker button is all of the way on (down towards you). If the light is not lit then you are on either CB or Intercom. The radio and CD player will play but you will get static and skipping noises (wonder how i found this out). Once the speaker button is on it eliminates all of those issues.
Old Dec 2, 2005 | 10:04 PM
06glide's Avatar
06glide
Thanks,
I'll be sure to check this out sometime this weekend..
Bert
Maryland [sm=yikesomg.gif]
Old Dec 5, 2005 | 03:44 PM
streetglide#1's Avatar
streetglide#1
I have had the same problems with my 06 flhx,last week I noticed a dark spot on the inside of the display and whatever had shorted drained my battery. I took it to the dealer(after a jump -start)and they replaced the radio,with no explaination of what happened,seems fine now.
Scooter68
Aug 21, 2009 08:37 PM
HawgriderPa
Mar 26, 2008 11:35 AM
chubbynj
Aug 13, 2006 11:54 PM
BowRider
Jul 5, 2006 01:11 PM
mfdbrian73
May 21, 2006 10:30 AM
