Performance upgrades...what to do first??
Old Nov 4, 2007 | 08:33 AM
  #31
gunnert's Avatar
gunnert
Default RE: Performance upgrades...what to do first??
You can do like most Harley owners, myself included, and start with pipes, breather, and remapping. Then you'll either add cams or big bore. Then you'll do the heads. Then you'll do the cams again, chain the exhaust, add a bigger throttle body, etc..... Get the picture. or... you can wait, read, and learn about the various "kits" such places as Head Quarters and R&R offer (there are hundreds of others). Then do your mods at ONE time and save about 50% of the money you have wasted picking away at it one step at time. I like to compare upgrading Harley's tothe saying, "why is it you always have time/money to do it right the second time...."
Old Nov 4, 2007 | 09:04 AM
  #32
Timex's Avatar
Timex
Ditto that ...
ORIGINAL: HarlyFan
Start with Pipes, Air Cleaner, Race Tuner
Old Nov 4, 2007 | 09:10 AM
  #33
rocksandgiz's Avatar
rocksandgiz
I`ve been thinking about doing the same to my 08 ultra. I've been reading on here alot and I think the cheapest way to add useable torque is with a 2-1 pipe. The D&D fatcat seems to be the best I can come up with, then the others follow close behind. Add a hi-flow A/C and a fuel managment system could probably do it youself for around a grand or less.
Here's a simple stage 1 that should yeild fairly good torque increase
1- hi-flow air cleaner $140.00
2- V&H pro pipe BP- 500.00
3- V&H fuelpak - $ 240.00
if you want to spend more you do this:
2 - D&D fatcat - $650.00
3 - PC III usb - 350.00
or
4 - or some kinda auto tuner instaed of #3 if wanted - $650 -$800.00
you should get good useable torque and HP increase for $900 to $1500 smackers and should let the bike run cooler also.
Good luck on your decision.
Old Nov 4, 2007 | 09:43 AM
  #34
NorCalrider's Avatar
NorCalrider
Since you are in California this adds a level of difficulty to making modifications. I seem to remember that you said your Ultra had warranty. If you are concerned about not voiding the warranty then you are pretty much limited to whatever the Harley dealers can do that is CARB approved. Since this is a used bike you may be limited to stage 1 upgrades (i.e. air cleaner, slip on mufflers and stage 1 download). If this is a concern then check with your dealer. Many on this forum will advise aftermarket modifications and I am sure thatsome of them are very knowledgable. But not all of them are concerned about warranty or our situation in California. I would say ride it a while and establish a dialog with your local dealer.
Old Nov 4, 2007 | 10:07 AM
  #35
jag1886's Avatar
jag1886
Mufflers, air cleaner, race tuner and don't skip the dyno time. Down loads are a bandage; dyno time is the cure. If you have to save up another month then do it. You'll be ahead in the long run.
Old Nov 4, 2007 | 10:12 AM
  #36
sugarbear's Avatar
sugarbear
I would go with a fuel management system first to help with heat. I like the tm with a/t because any other change you make are compatible with it.
Old Nov 4, 2007 | 06:08 PM
  #37
gunnert's Avatar
gunnert
oh yea, I forgot to add, if you want to be tired to $90+ an hour labor at Harley dealer, then go with the HD SERT (and keep in mind the narrow band HD 02 sensors are junk). The money you'd spend for SERT and one tuning session would pay for a Zippers Thundermax Auto Tune. My second choice when budget is a concern would be the PCIII and block off the 02 sensors.
Old May 8, 2008 | 04:41 PM
  #38
southern_hog's Avatar
southern_hog
4th Gear
i'm kinda like that last post about makin some mods to an 07 electra glide. i already bought the vance and hines tru duals with the ovals and the SE hi flow air cleaner but i was readin about the vance and hines fuelpak over the SERT... any comments or opinions?? and i'm fairly good with an engine, i can do my own maintenance and things so could i just put all that one myself or is that something i should let them do?? i'd love any comments or help!! thanks ya'll!!
Old May 8, 2008 | 04:54 PM
  #39
Q Hog's Avatar
Q Hog
great advice..
Old May 8, 2008 | 05:41 PM
  #40
dowork08's Avatar
dowork08
pipes, a/c, and a tuner of choice IE fuel pak, PCIII, race tuner. I personaly have bub 7's, PCIII, and a/c on my 08 SG. I love it
