low idle
Old Feb 18, 2008 | 06:23 PM
hogvibrator's Avatar
hogvibrator
Default low idle
[>:] my 01 road kings idle drops 100,200 rpm after i adjust it.i have a DFO, k&n air cleaner & true duals.I replaced intake gaskets & engine temp sensor, whats next?
Old Feb 18, 2008 | 06:26 PM
choochoo's Avatar
choochoo
Default RE: low idle
Is it fuel injected?
If so you can not just turn the idle screw.
You must do it by the procedure in the service manual.
Old Feb 18, 2008 | 07:41 PM
hogvibrator
[>:]i did it according to the book.
Old Feb 18, 2008 | 07:46 PM
hogvibrator
[>:] by the way its injected.
Old Feb 18, 2008 | 08:02 PM
choochoo's Avatar
choochoo
to do it right you're supposed to use a breakout box and measure the voltage on the
two pins called for. This voltage must be precise.
If you don't have a break out box, you can use two needles slipped in parallel to the pins called
for, on the ECM connector. ecm pins 16 & 30 and ground. With a digital volt ohm meter
YOu say you followed the procedure outlined in the HD service manual 99481-01
on pages 9-30 & 31?
Are any trouble codes showing?
Old Feb 18, 2008 | 08:04 PM
twistedcherokee's Avatar
twistedcherokee
Mine does the same thing. If I don't reset the computer it will get down past 800 rpm's in about a month of riding. While I was doing my cam chain tensioners I noticed that the Idle Control runs a lever that kicks the linkage in & out. I think I might try taking it loose all the way so that the idle screw sets the throttle body @ 1000 rpms then reinstall the IC and clear it all. If that don't work I may find a way to do a manual adjustment somewhere other than the idle screw.
Toby
choochoo's Avatar
choochoo
BTW you have to have the DFO removed when you set the base cold / warm idle.
What DFO are you using. And when does the rpm drop occur.?
Old Feb 21, 2008 | 10:13 PM
twistedcherokee
What is the DFO? I think my manual says to disconnect the Idle Control, set the idle and then disconnect the battery, then plug the IC inand reinstall the battery. It's been probabbly a year that I did it last. Every once in awhile I disconnect the battery, and it raise the idle back up. Maybe there is an adjustment for the IC that I am not doing. I will look at my manual on Sat.
Toby
troverman
May 5, 2014 10:19 AM
bcooper326
Exhaust System Topics
Dec 13, 2012 04:16 PM
mongomark
Jun 11, 2010 01:18 PM
WIRON
May 18, 2009 03:55 PM
boneyard
Oct 4, 2007 10:44 AM
